Rebuilt Carb Brand
Old 02-24-2016, 01:59 PM
idealtrucks's Avatar
idealtrucks
idealtrucks is offline
Rebuilt Carb Brand
I'm looking for a rebuilt carb for my '70 300.
Which brand do you guys recommend? Looks like Autozone has United, National, and Autoline.
Thanks!
Old 02-24-2016, 02:02 PM
hillcountryflt's Avatar
hillcountryflt
hillcountryflt is offline
I used a Carter YF rebuilt acquired from Rock Auto. Worked and is working fine. Pricing was OK and at the time last year finding a rebuilt carb was not all that easy - napa was weeks out, etc.
Old 02-24-2016, 02:07 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Unless it is plain worn out, why not rebuild it??
Old 02-24-2016, 02:18 PM
idealtrucks
I'm thinking it's plain worn out. I've rebuilt it before. It's always had a whistle as certain throttle positions which I believe it coming from the throttle valve shaft. It's also recently started leaking gas out that, so I'm thinking it's just worn out there.
Old 02-24-2016, 03:21 PM
hillcountryflt
I rebuilt the one on my 71. But on my 69, the lower portion/throttle body spring control would never come back all the way resulting in it sticking with the throttle a little open.
Old 02-24-2016, 07:32 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is online now
Is there any local carb business' there? Maybe some place local that can install bushings in yours.
Old 02-25-2016, 08:03 AM
idealtrucks
Unfortunatley, there's just a few local service stations. I'm in a very rural area.
Can you buy bushings for these and maybe use a drill press to bore out the holes?
Old 02-25-2016, 08:48 AM
hillcountryflt
there are some places you can send your carb to and have it rebuilt. Not cheaper. Carburetors and More in Texas would charge about $300. I have known people who have used them.
Old 02-25-2016, 10:12 AM
orich's Avatar
orich
orich is offline
I see some shaft bushing here at Mike's Look up your carb # go through the pages of parts.
Not sure if link will work, if not then copy to browser & search
Orich
Welcome to Mike's Carburetor Parts - Your Number 1 Carburetor Parts Store Mike's Carburetor Parts - Your Number 1 Carburetor Parts Store
Old 02-25-2016, 11:43 AM
idealtrucks
There's a bushing listed on that site. I may pull mine off and see exactly how bad it is first.
Also, there's some new China carbs on ebay for around 120. That's much cheaper than a rebuilt one if I end up having to go that route. Anyone ever tried one of those out?
Old 02-25-2016, 12:30 PM
Salty Dog's Avatar
Salty Dog
Salty Dog is offline
Orich
x2 on Mikes. Quality gaskets and good service.
Old 02-25-2016, 12:40 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
I never had much luck rebuilding junkbox carbs for some reason. They worked OK, but. Probably was the throttle shaft bushings, I dunno. Rebuilt carburetors are stupid expensive, but they might be worth it, IF they have done everything they are supposed to. A properly remanufactured carburetor will be bench flowed or run on an actual engine and the rest of it, as well as having a warranty and return policy. Spend a little more and have someone that will stand behind their product and service, and be there after the sale.
fluff
09-15-2018 07:44 AM
jjurva!
02-20-2013 06:51 AM
teardropty
17
11-26-2012 06:18 AM
DT 466Man
General Automotive Discussion
11-16-2004 09:29 PM
jjy120
06-30-2003 04:33 PM
Quick Reply: Rebuilt Carb Brand
