auto locking hubs part numbers - Ford Truck Enthusiasts Forums
Old 02-23-2016, 10:23 PM
carkivey3 carkivey3 is offline
carkivey3 is starting off with a positive reputation.
i have had this 2002 superduty for 12 years. 4wd auto been fine except i had to replace sol valve a few years ago. of course with the auto feature working so good i rotated the manual ***** less and less. now that i am replacing ball joints i wanted to free them up. friend at work cleaned and freed his up several years ago. however when it got to mine his memory was a little shaky. we could not figure out how to remove outer ****. we had the inner gears,springs, and other parts out. while looking for a snap ring internally we damaged the diaphragm under the cap. we now have it apart. of course now i need the diaphragm. most posts want to go to complete manual or buy all new hubs. seems like this diapragm should be less than $10. i cant find it anywhere. Guzzle mentioned that he does not take the **** out because the diaphragm usually gets damaged. he did not say where he gets new diaphragm when it does happen. anybody know the part number for this diaphragm. as mentioned earlier i want to keep it original and i dont want to buy a new $200 unit when a new diapragm will fix it
Old 02-24-2016, 01:40 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
I assume you have an F250.
Check ROCK AUTO for the parts you need.
Good luck.
Old 02-24-2016, 02:56 PM
sorry i moved this to the right forum now
How to Troubleshoot and Fix F150 4X4 1997-2003 revytrucks 1997 - 2003 F150 125 01-31-2017 11:30 AM
1978 Ford XLT Ranger 351M, New Carburetor Issues Nathan Vos 1973 - 1979 F-100 & Larger F-Series Trucks 7 06-25-2016 10:49 PM
auto locking hubs part numbers carkivey3 1999 to 2016 Super Duty 3 02-25-2016 03:34 PM
Distributor Issues on 352 FE bluestang65 1961 - 1966 F-100 & Larger F-Series Trucks 15 06-13-2015 01:04 PM
Knob idiocy ChrisAdams Ranchero & 1961 - 1967 Econoline 4 09-05-2011 02:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
