break showes
Wider shoes are for the front, narrow for the rear. The shoes with the longer friction material go to the rear of the wheel, the shorter friction material to the front. Do one wheel at a time so you can refer to the opposite wheel for guidance and hope the last person did them right. ;-) The number of holes means little as long as the ones you need are present (size of holes also counts.)
Sidebar: FWIW, I don't know what your plan is but I would never replace shoes without new hardware and rebuilding the wheel cylinders. When I began working on cars professionally, a complete four wheel brake job included new shoes, new hardware, resurface four drums, repack wheel bearings with new seals, rebuild four wheel cylinders and bleed the system. Price? $49. (point not referring to my age but rather to what was considered a 'normal' brake job in the day)
Received 4,130 Likes
on
on
Not sure if you are talking within each drum but clarification is needed to avoid confusion. In talking about front wheel brakes and rear wheel brakes, the wider shoes go on the front axle (2" on the F1) and the narrower shoes go on the rear axle (1 3/4" on the F1). Then, on self-energizing brakes (like on the F1) within each drum, the shoe with the shorter amount of lining goes toward the front of the drum and the shoe with the longer lining goes toward the rear of the drum. On non self-energizing brakes (like my F2), the lining material is typically the same length on both shoes.
The fact that the wider shoes go on the front axle and the narrower shoes go on the rear axle should be the same on single or double anchor. The short linings versus the longer lining discussion applies to self-energizing single anchor brakes such as those on the F1. Normally, double anchor brakes (like on the F2) have even length linings on both shoes.
Tedster9
21
10-22-2021 12:49 PM
Steve in NC
01-10-2017 08:03 PM
luke-gr
10-26-2010 10:39 PM
