Oil leak from the front crank?
A good cleaning is needed to be 100% sure that is where the leak is coming from. Like mentioned above if it is the oil pan or front cover than the engine has to come out in order to remove the pan.
Shot of the front cover with the harmonic balancer still on.
Use an impact with a 6 point 15/16 socket to remove.
Removal tool.
I forgot to get a pic before removing the LPOP but after there harmonic balancer is off remove the 4 bolts and off it comes.
Here is a shot of the LPOP gear on.
Under the water pump you can see the LPOP cover on.
Removal tool.
Here is a write up of when I pulled the motor, I think this link should take you to page 7 post 95. This is a step by step process on how to remove the harmonic balancer and getting to the LPOP minus the actual removal of the LPOP which is easy. Just remove the 4 bolts the hold the cover on. If your not going Melling LPOP it has to go on a certain way or major damage to the front cover can happen. The original LPOP will say which way to put on.
https://www.ford-trucks.com/forums/1...-w-pics-7.html
This shows the LPOP going on. The link should take you to the correct page but it is page 10 post 146.
https://www.ford-trucks.com/forums/1...w-pics-10.html
thanks for the replies. I will definitely hose it down and verify. I had the oil plan replaced a couple of years ago, so that gasket is newer. I can see it coming from below the harmonic balancer and then gets slung all over.
So if I understand. Remove belt, remove balancer, pop out seal insert new seal reassemble?
Okay so after much cleaning and scrubbing and watching. The leak is coming from behind the harmonic balancer for sure. How can I get an impact in there to get it off or even a puller for that matter? Is it a matter of just squeezing in there or should I remove the fan and fan shroud? Is the seal under the balancer or does the lpop have to come off too?
Sorry for all the questions.
The seal is on the outer part of the oil pump. There should be a wear sleeve on the balancer where the seal rides. The wear sleeve should be replaced as well. Before reinstalling the balancer, clean the crank snout and the mating surface on the balancer and put some sealant, preferably Ford TA31, on the key and in the keyway.
Okay so I have the harmonic balancer off. Do I just pull out the old seal and ring from the front? or do I have to remove the lpop housing. I would like to avoid that if I can. Is there a gasket that goes around where the bolts are? or just the o ring on the inside. Sorry for all the questions
Why not just replace the LPOP while you are there? The Melling M208 is known to be a good higher volume upgrade over stock. The oil pumps do wear out, as I have recently discovered.
Your signature doesn't list mileage, but since its an '02, I'll assume there is a decent amount of miles on it. I would at least pull it off and inspect for gear wear. There is also an o-ring behind the pump that could be leaking too.
I haven't experienced any of the symptoms of a weak lpop. Up in Canada working outside in the snow and just want to get the oil leak fixed. I know it's half *** but this is my only vehicle and I need to get back to work. The oil was falling from the back of the balancer so i'm pretty sure its the seal and not the O ring. I would have to order a new oil pump from the US and wait a week at best. Which I cannot afford.
