Vacuum Reservoir plumbing
Old 02-22-2016, 11:57 AM
CaptPayne's Avatar
CaptPayne
CaptPayne is offline
Morning All,
Getting near to getting the engine fired up and cab back on my '51 F5 Marmon Herrington 4x4 and am looking at getting a vacuum reservoir to "improve" the stock wipers instead of going electric.
But, since I've also got the brake booster I'm wondering if I should keep the stock check valve and put the reservoir on the wipers only; or put a tee in after the reservoir, do away with the stock check valve, and feed both the wipers and the brake booster?
Cheers,
Mike
Old 02-22-2016, 01:09 PM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,410 Likes on 1,370 Posts
You'll want to leave the brake vacuum line alone so it operates as it does now. Where the wiper vacuum line attaches to the manifold currently, run that line to the new vacuum can with a check valve, then run the wiper line, and any other vacuum accessories you might have, off of the can.
Old 02-22-2016, 01:16 PM
CaptPayne's Avatar
CaptPayne
perfect! that's what I was wondering. Thanks Wayne.
Pictures to follow tomorrow of my rebuilt booster on the rebuild thread. To go with a new master, and new lines.
Mixer man's Avatar
Mixer man
Mixer man is offline
I'm planning on something similar on my F-6. I have an old three gallon Freon canister that I plan on using as a reservoir with a vacuum check valve low vacuum warning light. I'm going to tee it in downstream (away from the carb) of the OEM check valve.
Scndsin
10-10-2017 10:35 AM
roadrunner01
08-08-2017 11:36 AM
john smith jr
11-25-2008 08:39 AM
ladiabla74
1997 - 2003 F150
07-30-2008 09:03 PM
hotbbb
02-02-2004 02:37 PM
Quick Reply: Vacuum Reservoir plumbing
