Somewhat low oil pressure.
Hi all ! I have a 2001 7.3 Ex has 203k. I hooked a oil pressure gauge to it. Hot engine was 12 psi at idle 36 psi at 3300 rpm and anything over 3300 rpm it would go down to zero. Chiltons say idle 10psi and 3300rpm 40 to 70 psi Oil level was fine. I use Rotella 15 40. My question is for a truck with that many miles is that ok or is there something I need to be checking.
Low pressure oil pump could be worn out. New one is not overly expensive and not too hard to replace. You'll need to rent or borrow a couple of specialty removal install tools for the wear ring.
Lot's of good reading for you here to get started.
https://www.ford-trucks.com/forums/9...p-install.html
Wear ring replacement info thanks to Nicmike
https://www.ford-trucks.com/forums/1...il-leak-2.html
toolboxjunky
04-09-2009 05:01 AM
boond0cksaint
05-04-2004 07:07 PM
