rebuilt 3 speed
Old 02-22-2016, 12:10 AM
saauvenshine's Avatar
saauvenshine
saauvenshine is offline
rebuilt 3 speed
Just found a rebuilt 3 speed trans and bell housing with 11 inch clutch and pressure plate out of a 1958 truck with 292. I believe I have a 10 inch clutch and pressure plate on the 54 239 engine in it. I notice the only difference is the 292 trans has a larger input shaft and looks like a hydraulic hook up on the side. Will this work fit and work on my 239 if I just pull mine and put this back in.And can I just pull the hydraulic fitting of since my 54 is not equipped for it. I was not for sure.
Old 02-22-2016, 09:57 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is online now
Yes, you can remove it. The hydraulic hook up (aka power take off PTO) was for something additional i.e. Winch, hydraulic drive for a dump etc.
Old 02-22-2016, 07:52 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
I think he's saying the '58 has a hydraulic clutch instead of mechanical?
Old 03-02-2016, 06:55 PM
saauvenshine
3 speed trans
Hey guys just figured out that the unit bolted on bell housing is a slave cylinder used on maybe on 59 or 60 y block. Can I just remove the slave cylinder and be alright.
Old 03-02-2016, 07:38 PM
bjmayberry2
We'll that definately makes my earlier comment null
You'll need all the stuff including the pedal assembly to make it work (off your old tranny & bell housing). You'll also need to replace the pilot bearing in the rear of the crank shaft. Does the new Transmission have the two bolt holes on the drivers side to mount the clutch pedal assembly?
saauvenshine
03-07-2016 04:58 PM
Gary Huff
1997 - 2003 F150
12-31-2009 06:50 PM
skipr
11-15-2009 10:02 AM
Hamutoff
11-11-2008 01:03 PM
Fordman84
05-02-2000 08:55 PM
Quick Reply: rebuilt 3 speed
