92 f150 4.9L slight miss/hesitation under light gas pedal pressure
#31
#33
#34
V8,
i am also dealing with the notrious bucking f-series. After reading posts on this for days, i have concluded that it is the fuel injectors clogging up. With the egr putting the normal amount of exhaust into the intake and the clogged fuel injectors puttiing in less gas, you get the bucking and stumbling. restricting the egr will solve the problem, but it is only compensating for the lack of fuel. The injectors need to be serviced. take it to a shop and have them cleaned. don't let them tell you you need new ones. Personally, i put half a quart of ATF into half a tank of gas and am going to run it out. ATF has some pretty hefty detergents in it that should do the trick. I'll post the results.
#36
#38
smitty,
I believe that my injectors are causing my problems. Let me know what happens with the trans fluid.
My valve cover is leaking. And if I go that deep into the engine, I may go ahead and change out the injectors too. I found a guy on ebay that sells them pretty cheap compared to the part stores.
Set of 6 1992 Ford F150 F250 F350 4.9L Fuel Injectors - eBay (item 280636229938 end time Mar-28-11 12:28:30 PDT)
#39
Why replace the injectors? Their an on/off solenoid and either work or don't. Take them off, remove the pintle caps, orings, and filters in the injector inlets and soak in ChemTool for a few days like you would jets from a carb. Then, remove from chemtool and use an injector test harness from the parts store and give each one 12 volts from the battery and blow them out with compressed air in the reversed direction. I.e. backflush them to blow any crud back out the injector inlets.
Buy this kit and rebuild them. I would only replace an injector if it doesn't "click" when you apply 12 volts to it or doesn't let air through when you energize it.
So $20 for the rebuild kit, $5 for the chemtool, and $5 for the upper plenum gasket and your done.
Doing this job got rid of the off idle stumble my 280K mile 95' 5.8L had. I reused my injectors with that much mileage without a problem.
#41
well i fixed my issue. fuel filter properly gapped plugs and seafoam. that stuff does work. im amazed. i dont like pur in bandaids but it really cleaned the injectors really well. i didnt pull them out and put them on a flow bench but the truck sounds so much better has t-responce again and gets better mpgs. tranny even shifts better.!
#42
So glad that I found this thread. I taped off the vacuum line and it solved the problem in my case! I will do a more permanent solution at some point, just had a few questions first.
1. Smitty, how did the ATF work for you? did that clean your injectors and solve the problem?
2. Has anyone tried crimping the inlet on the EGR valve instead of using the restrictor plate or the tin foil? This would allow it to not throw a code, and also restrict the airflow.
Truck has so much more power now. Before I had to give it a fair amount of gas when starting off in 2nd gear to prevent it from stalling out. Now I can give it a little and it will not drop revs at all in 2nd. I notice that I can go through 2nd and 3rd gear quicker now, which is nice - 1st gear is still too quick though
-dan
-dan
#43
#44
