1992 F250 Dana 50-60 Front Axle questions?
Hello everybody. My '92 F250 4x4 has a Dana 50 SRW front axle in it. I've found a Dana 60 axle housing fairly cheap that I'm thinking about buying. It's just the bare housing and it's ball joint style just like my 50 is. So, what all parts can I use off of the 50? I'm hoping stuff like the brake rotors, brake calipers, and (even though the steering linkage is different) the steering pitman arm can be used on the 60 because all that stuff is fairly new on my truck, but it would be sweet if I could use all the outer stuff (except tie-rods and such) and only have to buy the inner stuff (axles, ring and pinion, bearings....). So, if someone could give me a list of what can be swapped and what I would absolutely have to buy I'd highly appreciate it. Thanks in advance.
biederboat
10-23-2014 03:48 PM
78 Ranger
16
07-15-2005 03:46 PM
keepnthepeace
04-29-2002 04:43 PM
