7.3 Engine Block Heater
The timer part i will agree with, it will help save money on electricity.
Cable routing pictures?
A number of years ago, I found most of my block heater cable on the driveway, a victim of a family of blunt-tail wood rats. I haven't needed the block heater until now. I bought the new cable <WHEW>and want to install it, but what holes do the little spikey things go into. A picture would be great <VISUAL person>. I can probably interpret through the snow and mud deposits.
Thanks, Chris. Late last night I finally found it, hidden under a flap on the drivers side in front of the radiator, tied to two connectors like it has obviously never been used.
Just bought it about a year ago -- first diesel ever, first PSD ever. 150k in great condition.
James in GA
2001 F350 Lariat 7.3 CC, LB, SWB, Leer truck cap
James in GA
And welcome to FTE
James in GA
James in GA
The only issue I can see with the heater elements would be the accumulation of grundge on the elements causing less heat transfer to the coolant, thus longer warm up time. Sort of like your electric hot water heater elements that build up over time.
Other that this, the heater is quite heavy duty. I also plug mine in for several hours (on a timer) year round. During the winter, I think this prolongs the life of the glow plugs if done the life of the truck.
This thread will tell you all you need to know, post #6 has a pic. https://www.ford-trucks.com/forums/9...-location.html
And welcome to FTE
And welcome to FTE
That's an excellent close-up photo. I'd never have thought of crawling under with a camera.
Since it was just below that plug that the cable was gnawed off by the packrats, I'm not sure how to route the new cable I just got. It has flexible (accordian-pleat covered) cable on the outer third at each end, but the middle third (roughly) has a hard, inflexible covering, so I'm guessing it can't just get zip-tied any-old-where. All along the length are taped on 'spikes' that must get pressed into some holes in the frame or wheel well ...
Given the cost of the cable, I want to make sure it gets put in so that it won't get damaged. I don't have the old cable there to go from. You start from the front and thread it in toward the rear?
[quote=rcb_in_nv;8392963]Thank you.. this is a really fine site.
Given the cost of the cable, I want to make sure it gets put in so that it won't get damaged. I don't have the old cable there to go from. You start from the front and thread it in toward the rear?[/quote]
I would start at the heater and work towards the front myself. I will try and see if I can find the routing instruction for the cord. I have them some where.
Like seeing a 6 1/2 year old post still helpin' folk. It's why I joined. For those of you just finding your heaters, don't pull my stunt and back out of the drive still plugged in. Several times before I finally started hanging the extension cord over the DS mirror. Unfortunately I think too late. My heater quit working. I've read some post where it might be just the cord. Just another item on the list.
#28
Don't force it in. Gently feed it into the receptacle and when its correct, it'll seat itself flush against the opening.
Make sure to use the wire keeper over the threads of the heater to ensure that the cord stays in place during your "adventures" with the truck.
#29
Two by Ford,
My heater also quit working and I found that it was open in the male plug. I cut off the cord and installed a new plug...works as good as new. I tested it with an ohm-meter and it tested open, so I used a pin to poke thru the insulation about 6" back from the plug and tested each conductor. ! showed the short like it should and the other tested open, so I tested it again about 1" from the plug and go the same results. Then with pins in both conductors I "looked" at the heater and got about 14 ohms which let me know it was good to the heater. I cut off the plug about 1" behind the plug and installed the new male plug. The old plug was bad inside the plug itself. Hope this helps.
Ray
Ray
#30
