Oil drain plug location--Please help! - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 08-10-2003, 09:29 PM
Razor19454 Razor19454 is offline
Razor19454 is starting off with a positive reputation.
Angry Oil drain plug location--Please help!
For some reason, I am unable to locate the oil pan drain plug on my 2003 Ford Escape (1st oil change).
Maybe I am blind, but I would appreciate any help.
There's no Chilton's or Haynes manual available yet.
Needless to say, I feel like a knucklehead and am more than a little frustrated.
Old 08-12-2003, 09:51 PM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
On a V6 right?? OK, going in from the front, if you look under the car, you'll see the pan. It's cast aluminum, looks like a waffel. It's on the back side if that facing the rear of the vehicle. If it's your first time then expect the plug and filter to be TIGHT!
Old 08-13-2003, 01:49 PM
pilot10 pilot10 is offline
pilot10 is starting off with a positive reputation.
One other thing. Expect to drain oil all over your exhaust when you remove the filter!!!! Ford should fire the dang brain donor engineer who placed the filter there. At least my 150 has a plastic piece to direct the dripping oil onto the ground(or properly placed pan) instead of all over the bottom of the engine.
It's about time to change the oil again on the wife's Tribute(2nd time) and this time I'm thinking of fashioning some sort of funnel(it's a tight space) to collect the filter's oil in a container instead of having to wipe it off the ground.
Tim
Old 08-13-2003, 10:00 PM
Thanks much. that's a big help. I think I will use a piece of one inch hose to minimize the mess.
Old 08-14-2003, 03:37 PM
cyclenut cyclenut is offline
cyclenut is starting off with a positive reputation.
Hello all,
I have a 99 f-150 and for some reason I have become as blind as anything out there and I cannot find my oil drain plug . I would greatly take any advise anyone can give. It's a 4.2L , Thanks much , Signed Blind as a bat
Old 08-27-2003, 09:25 AM
MSRanger MSRanger is offline
MSRanger is starting off with a positive reputation.
Quote:
Fram is now selling an replacment oil drain plug fitting/hose combination which would eliminate the mess from the drain plug area. I saw them in the WallyMart the other day. They were over $10 though...
As for the oil filter, I don't know about the Escapes particularly, but maybe a one gallon milk plastic milk jug with the bottom cut out might help funnel the drain oil from the filter area off of the exhaust?
Loosen the filter first, then reach up with the funnel in one hand, and twist the filter loose with the other?
Leave the funnel in place for a few minutes while the initial oil drains off, then remove the filter the rest of the way.
Depending on whether the Escape filter is mounted straight up, or angled to the side, it might work well.
Old 09-03-2003, 06:34 PM
PrPlayboy PrPlayboy is offline
PrPlayboy is starting off with a positive reputation.
Most oil filters are a pain in that way. I just let the oil filter drain into the black drian pan. After everything finishes I clean the screw and screw the new filter in. i wipe off any excess oil and the rest burn offs.
Engine Oil Pan/ Drain Plug Matt1966 1973 - 1979 F-100 & Larger F-Series Trucks 17 12-05-2016 12:57 PM
oil rail drain plugs drpaul311 1994.5 - 1997 7.3L Power Stroke Diesel 9 10-24-2012 04:18 PM
2007 expedition front differential plug recluse 2007 - 2014 Expedition & Navigator 0 10-29-2011 12:02 PM
help! c6 and gear vendor oil change??? mark vanford 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-30-2011 09:27 PM
oil drain plug stripped 94f2507.3td Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 09-16-2005 11:18 PM
Tags
2003, 2007f150oildrainplug, 42, drain, drian, escape, f150, ford, located, location, mazda, oil, pan, plug, tribute
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
