smog pump delete - Ford Truck Enthusiasts Forums
smog pump delete
Old 08-10-2003, 07:49 PM
CrazyFordMan CrazyFordMan is offline
CrazyFordMan is starting off with a positive reputation.
smog pump delete
I am in the process of rebuilding my 5.8 and i want to get rid of my smog pump and i want to know if i can get rid of all the hoses that come from it and snake all over the place. and also dose any one make plugs for the back of the heads or do i make my own?
Old 08-10-2003, 09:46 PM
smog pump delete
ttt
Old 08-10-2003, 10:37 PM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
smog pump delete
Why? It won't make the engine run any better, and probably worse. Keep it running right and it'll be more reliable and easier to diagnose.
Old 08-10-2003, 11:30 PM
Hit Man X Hit Man X is offline
Hit Man X is starting off with a positive reputation.
smog pump delete
Well my pump is coming off as it is useless on my truck. The pump isn't hooked up the the cats as I run longtubes, that Smog pipe on the back of the heads is gone too.
Ford sells those head plugs, do a search on here for them that I posted up on them. I have them on my truck as my Smog pipe rusted out.
The check valves are gone also.
The belt needs to be ~5-10" shorter
Old 08-11-2003, 09:50 AM
smog pump delete
did you get rid of all the hoses that run all over the place?.
also what do you guys think of using the smog pump as a on board compressor. would it work???
Old 08-11-2003, 10:19 AM
smog pump delete
I will be getting rid of those vac lines pretty soon. Only thing that is going to stay is the EGR system w/ vac line and the fuel pressure regulator vac line.
The others go to the TAD/TAB solenoids which are useless as the smog piping and check valves are gone. I will leave the solenoids and wiring to them to avoid a CEL/SES/MIL light...whatever you call them.
Smog pump just pulls air through it to the other stuff, not really a compressor more like a small sealed fan
Old 08-15-2003, 12:59 PM
Felter Glutsch Felter Glutsch is offline
Felter Glutsch is starting off with a positive reputation.
Talking smog pump delete
Just did the same on my F350 crew dually with 7.5L.
I just snipped the air tubes and welded them shut removed the smog pump and the Cat. ( I have a 5 speed and with out the cat it sounded like a tank firing every time I pushed in the clutch). The extra air from the air injection tubes was causing this.
The truck runs a lot better now and is even using less gas.
I removed all the extra smog junk and it looks better under the hood too. Installed 3 inch flowmaster system and all is well. I now get about 400 miles out of full thanks. Not bad for a giant warhorse.
Old 08-15-2003, 02:19 PM
smog pump delete
Hey not bad for that giant! Did you remove that "Folgers" can from under the hood also?
Old 08-16-2003, 03:05 PM
smog pump delete
so you got rid of the air pump and all the 5/8'' rubber hoses that were attached to it? what about the mess of hoses and valves that sit above the driverside fuel rail did you get rid of those too??
Old 08-16-2003, 03:30 PM
smog pump delete
Air pump is gone. Rubber hoses to the cats are gone. Hoses to air tube on heads is gone.
I am in the process of sorting out the vac mess.
You need the "Folgers Can" as that supplies vac to the EVR valve by the TAD/TAB solenoids next to the coil. The TAD/TAB are for those check valves by the back of the heads and the one by the air pump.
The EVR regulates the EGR valve so that's really the only part that needs to stay.
Vac runs from the intake to the "Folgers Can" then to the EVR then to the EGR.
Old 08-17-2003, 07:09 PM
smog pump delete
The "Folgers Can" is gone too, my year model truck has kind of a oval shaped can that controls the EVR. The Folgers can on mine was justa muffler for the extra air. since the pump is gone this was no longer needed. the fuel rail on my 460 is on the passenger side and all the extra 5/8 hoses are off and no longer needed. I Hooked it to the sunmachine in my shop (military)
and no codes or wrong readings. The warhorse really runs better and is alot quiter(unless you put the pedal to the metal).
The truck sports-3 inch flowmaster dual exhaust, free flow heads and a K&N Fip kitt. Its been a good truck if you don't mind having the manual transmission rebuild every 75000 miles(2nd and 3rd gear syncros in fords are crap)
I Just ordered a Center Console out of a 2003 Super Duty.(e-bay $69 plus shipping) Haven't received it yet. Will post when I get it and remove the front center folding seat and put in the console.
Old 08-19-2003, 02:49 PM
MrCarlsonq's Avatar
MrCarlsonq MrCarlsonq is offline
MrCarlsonq is starting off with a positive reputation.
smog pump delete
Ditch the smog pump, it doesn't make the engine run any better, it just makes the cats work better and sucks HP.
It won't work for onboard air because it is high volume, low pressure, it would never build the pressure you would want (the A/C compressor, on the other hand)
EGR doesn't make your motor run any better either. I am experimenting in removing that on the truck. It shouldn't cause any problems (it doesn't on a mustang) and would only throw a code... but when I left the vacuum line disconnected (vaccum leak) it did throw the check engine light. I will pull it and plug it to make sure it doesn't throw the light. Once you replace the EGR with a blockoff plate (better mileage, cleaner intake) then pull the coolent lines off the intake and get a little better HP! (I have done this to all my mustangs, but just bought the truck last weekend and haven't gotten to it yet).
Hope it helps.
Old 08-19-2003, 11:49 PM
c_rossman c_rossman is offline
c_rossman is starting off with a positive reputation.
smog pump delete
EGR does have a benefit of lowering exhaust temps and reducing pinging. I removed mine off my truck just because I was going to replace it like a good boy but twisted the exhaust tube off and also broke off of the exhaust manifold. So now I dont have an EGR and my Check engine light is on all the time. Just cant wait until the thing burns out.
Old 08-20-2003, 08:20 AM
MrCarlsonq's Avatar
smog pump delete
Lowering exhaust temps is the equivalent of lowering HP, I rather avoid that. And you shouldn't need your EGR to reduce pinging, as you shouldn't have much of a pinging problem at part throttle, which is the only time the EGR is active.
As far as the light issue, There should be a way to disconnect the EGR without getting the Check engine light. It is easily done with the EEC-IV systems on a mustang, Has anyone removed their EGR and not had a check engine light (I presumed my light came on because I had a vacuum leak (I pulled the vaccum line to the EGR while cleaning the motor and forgot to reconnect it).
Old 08-20-2003, 08:27 AM
smog pump delete
The check engine light comes on because the EVP sensor is out of range because it is not hooked up. The ECM leans out fuel mixture when it thinks the valve is opening, If the ECM sees the valve opening, but isnt hooked up you will get a ping or hesitation.
Smog Pump Plugs? BigBlocker0248 1987 - 1996 F150 & Larger F-Series Trucks 5 11-04-2016 09:24 AM
egr and smog pump delete ChrisZX2 Ford Inline Six, 200, 250, 4.9L / 300 11 04-25-2016 08:35 PM
air injection and smog pump delete xc4jokestomper 1987 - 1996 F150 & Larger F-Series Trucks 11 03-15-2016 03:59 PM
A/C and Smog Pump delete 90' XLT 1987 - 1996 F150 & Larger F-Series Trucks 8 02-16-2015 06:05 PM
gettin rid of emissions crap 85351ho Offroad & 4x4 3 10-20-2000 06:18 PM
Tags
1993, 460, 75l, air, delete, egr, exhaust, f150, ford, noise, pump, remove, removing, smog, tube, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
