smog pump delete
Old 03-07-2011, 02:46 PM
kjgibson2's Avatar
kjgibson2
kjgibson2 is offline
Originally Posted by ditchdoc99
Well I removed all the smog crap from my 460, I gained about 2mpg.. I still need to measure and get the correct size belt so I can remove the smog pump, there's nothing hooked to it but I'd like to remove it... Does anyone have a part # for the correct size belt??? The truck runs great...
Also I removed the EGR and as suggested in post # 21 I installed the Original EGR Eliminator $20.00 from RJM Injection Tech » EGR Eliminators ... Worked as described no CEL
What all did you delete? EGR valve, air pump, what else, and are you sure about the mileage increase? If you got 2 more MPG's that's awesome. i could look forward to 10-13 mpg's lol
  #47
Old 03-07-2011, 02:55 PM
kjgibson2's Avatar
kjgibson2
I was looking at the RJMinjectiontech site, I have a 1992 460, do I need the original EGR delete plug and the EGR eliminator 2 or can I just get the Eliminator 2 and put it into my harness?
  #48
Old 03-07-2011, 04:20 PM
ceetwarrior's Avatar
ceetwarrior
ceetwarrior is offline
I removed my smog pump/tubes/hoses. Then I just welded the a cap on the cat where the smog pipe used to go. I left all the EGR stuff..
I haven't noticed any gas mileage or power increase but it sure cleaned up the engine bay, much easier to work on passnger side of engine.
  #49
Old 05-22-2014, 03:52 PM
02dynadude's Avatar
02dynadude
02dynadude is offline
great info guys, thanks for all of the posts. i cant wait until someone adds some pics or a detailed description of the entire process.
  #50
Old 05-22-2014, 04:16 PM
mramc1's Avatar
mramc1
mramc1 is offline
I wrote up a process with pics from my truck this past winter.
https://www.ford-trucks.com/forums/1...with-pics.html
90' XLT
07-30-2022 02:22 PM
xc4jokestomper
27
11-10-2021 05:28 PM
BigBlocker0248
11-04-2016 09:24 AM
ChrisZX2
04-25-2016 08:35 PM
87coachman
11-03-2011 04:47 PM
Quick Reply: smog pump delete
