smog pump delete
#31
im pretty sure its my knock sensor that is retarding my timing and making ny truck lose horsepower because when i take off in first and get going and the shift it into second its lame but when the rpms hit 2000 and up it will put you back in the seat. you can actually feel it and i dont know why its doing that
#32
That's just the 302's powerband. My truck is the same way, starts to make decent power above 2000 rpm. You can unplug it if you want, just to see if there is any difference, but I don't think there is any way to just bypass it entirely (probably not a good idea either if it still works and is keeping the engine from pinging).
#34
#36
Well I removed all the smog crap from my 460, I gained about 2mpg.. I still need to measure and get the correct size belt so I can remove the smog pump, there's nothing hooked to it but I'd like to remove it... Does anyone have a part # for the correct size belt??? The truck runs great...
Also I removed the EGR and as suggested in post # 21 I installed the Original EGR Eliminator $20.00 from http://rjminjectiontech.com/?p=9 ... Worked as described no CEL
#37
#38
Removing the smog pump will gain you nothing and could lead to a lean condition. I know this first hand, i took out mine some months ago because of the lack of spare parts (can't find a replacement thermactor in Venezuela), and there were absolutely no gains, neither in mileage nor power. The result could be different on other engines, mine's a 302.
#40
Just to make sure you know what your getting into be prepaired to remove your exhaust manifolds so you can plug/weld the air tube holes mine were located on the fire wall side of the manifold... The main reason I did mine I was removing the exhaust manifolds to replace my gaskets and I broke a couple of the air tube fittings, but I ended up getting better gas mileage and I can actually SEE my engine now.... So I'm very pleased...
#42
It's an air pump driven buy a fan belt, it part of the emissions system on your engine... It injects air into the exhaust system...
#43
smog pump delete
I have a 93 f150 that originally had a 302 with a 5 speed that i swapped for a 5.8. when i first did it, i wasnt happy with the power (not much more than the 5.0) and worse mileage (about 13) i ttook off my smog pump and gutted the cat. and gained tons of power and mileage. it now gets about 17 to the gallon, and has more power than my other truck that has the 460, which is now getting the smog pump delete on it. i found in a junkyard a bracket and pulley to go in place of the pump. also, on the back of the heads i just tapped pout the holes and bought plugs to fit in. very happy with how the truck has ran since
#44
#45
I'll be removing mine when I install my new headers in a few weeks..... and I'll post up some pics!
