smog pump delete - Page 2 - Ford Truck Enthusiasts Forums
smog pump delete
Old 08-20-2003, 09:37 AM
MrCarlsonq's Avatar
MrCarlsonq MrCarlsonq is offline
MrCarlsonq is starting off with a positive reputation.
smog pump delete
But, the whenever the EGR comes on, the ECM is in closed loop, so it is controling the mixture based on the O2 senser. If the EGR doesn't open, and it goes lean, it will immediately adjust because the O2 sensor says it is lean.
With my mustangs, I have removed or disconnected the EGRs on all of them, and have no lean issues. I have dyno'ed one of them with a wide band O2 hooked up, and would have noticed it lean out when warming up the car before the run (constant low throttle warmup).
Old 08-20-2003, 11:37 AM
fishin1976 fishin1976 is offline
fishin1976 is starting off with a positive reputation.
smog pump delete
To avoid the CEL from removing the EGR, mount your EGR valve on the fender well and run the wiring and the vacuum to it. The computer does not know if it is flowing exhaust gas or not, just if its plugged in. Like stated above, the O2 sensor will compensate for a lean or rich condition. That is an afterthought of introducing exhaust gases in the combustion chamber.
If you want the egr system gone completely, you will have to put up with the CEL or disconnect the bulb.
Old 08-20-2003, 12:02 PM
c_rossman c_rossman is offline
c_rossman is starting off with a positive reputation.
smog pump delete
You are better off removing the vacuum line and sticking a bolt in it, Then the ECM thinks the vavle is closed and wont adjust timing and mixture. I have had bad pinging and drivabiltity because of this
Old 03-05-2007, 09:00 PM
mechman40 mechman40 is offline
mechman40 is starting off with a positive reputation.
95 f-350 460
Did you have any luck with the truck? I have a 95 f-350 460 EFI , I'm in the process of installing a reman. mrt. and would like to remove as much of the smog ( airpump, egr, etc. etc.}with out effecting the proformance. Thanks for your time.
Old 03-05-2007, 09:16 PM
BigJim191's Avatar
BigJim191 BigJim191 is offline
BigJim191 is starting off with a positive reputation.
It's too bad i couldn't remove my smog stuff and cats too...but up here in Canada we have emission tests every other year...and i have another 7 years to wait
Old 03-05-2007, 11:59 PM
Trickedout420 Trickedout420 is offline
Trickedout420 is starting off with a positive reputation.
or you can just buy this kit to properly get rid of your EGR
http://rjminjectiontech.com/?p=9
Old 03-06-2007, 09:19 PM
BigJim191's Avatar
Thank you Trickedout420 for the link...i could use the eliminator until test time...remove it for the test then reinstall after.
Jim
Old 03-07-2007, 01:00 AM
buffalobob buffalobob is offline
buffalobob is starting off with a positive reputation.
how about that black plastic small car battery sized thing on the passenger side inner fender....with the vacuum lines going in - out of it?.....what is that thing????....and can I just plug all the lines and be OK?...the previous owner took off the cat and the air pump is pumping to atmosphere. Its a 7.5 liter...but the small blocks have this clutter too.
Old 03-07-2007, 02:26 AM
Jrock909 Jrock909 is offline
Jrock909 is starting off with a positive reputation.
In fact guys you can bypass all of the emissions solenoids also by using 75ohm-10 watt resistors on each of the solenoids...
Old 03-07-2007, 11:24 AM
jk89cat jk89cat is offline
jk89cat is starting off with a positive reputation.
that is the proper way to do it , if you leave it where the cel is on you will have driveabilty issues due to the computer being in limp mode . so you have to have the bypass connector deals like above or you need to have a tune that turns off the functions inside the pcm . great link btw trickedout420
Old 03-07-2007, 12:21 PM
nastruk95 nastruk95 is offline
nastruk95 is starting off with a positive reputation.
The thing on the passenger side is probably the carbon canister your looking at. It takes gas fumes and burns off the fumes instead of releasing them into the atmosphere.
Old 03-08-2007, 01:01 AM
Jrock....whats that about the resistors?????...can you fill in some details on that?...I dont have a clue what that means and need to do something w/ this 94 460...thanks
  #28
Old 03-08-2007, 09:47 AM
chadc2003's Avatar
chadc2003 chadc2003 is offline
chadc2003 is starting off with a positive reputation.
i thought about doing the resistor trick too but i wasnt sure if it would work. what about on a 96 f150 with a 302. for like the knock sensor and the dpfe sensor and stuff lik that
  #29
Old 03-08-2007, 10:06 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
Why do you want to eliminate the knock sensor? 96 is going to be more tricky in all respects since it is OBD-II and it monitors everything a lot closer.
  #30
Old 03-08-2007, 11:16 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Sounds like this is a pretty popular issue, Maybe a few of our members with expereince should write an article about it.
That way we have something to point new users too when they ask.
This is something i'm interested in also. Haveing issues with mine being all cut up, and my truck not performing the way it should due to the previous owners stupidity.
Smog Pump Plugs? BigBlocker0248 1987 - 1996 F150 & Larger F-Series Trucks 5 11-04-2016 10:24 AM
egr and smog pump delete ChrisZX2 Ford Inline Six, 200, 250, 4.9L / 300 11 04-25-2016 09:35 PM
how to get rid of smog pump mktaylor90 1987 - 1996 F150 & Larger F-Series Trucks 1 03-03-2010 11:15 AM
Removing smog pump from 96 F250 351W 93'colttsi 1987 - 1996 F150 & Larger F-Series Trucks 4 06-30-2008 09:04 PM
351m smog crap THEBOOGIEMAN 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 5 09-14-2006 10:00 PM
Tags
1993, 460, 75l, air, delete, egr, exhaust, f150, ford, noise, pump, remove, removing, smog, tube, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
