Yet another DEF question
Old 02-18-2016, 05:55 AM
Nearly Normal Mike's Avatar
Nearly Normal Mike
Nearly Normal Mike is offline
To add or not to add, that is the question.
2015 6.7 with 9K miles. Many say don't add DEF until warning light appears or it will confuse computer. I have no warning but under information option it says "less than half full". Add now or wait?
Thanks.
Old 02-18-2016, 06:10 AM
capt caper's Avatar
capt caper
capt caper is offline
You can add it... I've added it under many circumstances and any issues or lights will go away on restart or after awhile both on my 2011 which had 125k when traded and now 19k on the 2016. But I never had had any lasting issues. When it gets well below zero here filling it may be hard. It freezes in the filler tube..then can't fill until the truck has run for many miles..so I fill it before a artic blast now.
If it doesn't take it to the dealer because some thing is wrong with the unit.
Just add it when and were you want. Add it when the truck is off. That's what I do..
Old 02-18-2016, 07:00 AM
Nipperdog's Avatar
Nipperdog
Nipperdog is offline
I have been driving Ford 6.7s since 06/10, and I never let my DEF fall below 1/2 full. I have never had any problem whatsoever.
Old 02-18-2016, 07:25 AM
Irelands child's Avatar
Irelands child
Irelands child is offline
I add a 2-1/2 gallon jug from Wally World when the dash info screen says it's below 1/2 full. Been doing it since I bought the truck with no 'confusion' on the 'puter so far. Only one time did I let it go to the warning message and that took more miles then I thought it should to reset.
Old 02-18-2016, 08:11 AM
ct diesel's Avatar
ct diesel
ct diesel is offline
There is a guy on this forum user name Tom. Who is very knowledgeable. and gave me some advise. every once in a while check to see under information and see if you are under 1/2. When you see it add one 2 1/2 gal. jug.
Waiting for empty you end up with a little left over and a waste in the second jug. Unless you go to a truck stop and fill it up there.
Old 02-18-2016, 08:29 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
I don't fill till it is way down, around 200 miles. Then it will just about take two of the 2.5 jugs.
Using the ford fill spout will prevent any leakage while filling and will not over fill it either.
Then rinse and seal the bag for the spout for reuse.
That is what I do.
I also don't fill fuel and def at the same time. Prevents a fubar in my eyes.
Old 02-18-2016, 08:35 AM
Superduty450's Avatar
Superduty450
Superduty450 is offline
My 2015 was showing under 1/2 full so when I got to a truck stop (Flying J) using the DEF nozzle and filled it up, took 3.7 gal and the computer reset immediately. $2.80/ gal beats those jug prices and its easier. This is the 2nd time I have done this, truck has 10K on it.
Old 02-18-2016, 10:38 AM
jwsrules's Avatar
jwsrules
jwsrules is offline
Hi I'm like most others gave commented, I check system info everytime I fuel up to record hrs and if it says under half I well put a jug in within a 1000kms and the system resets as it should. Previous owner was my bro in law he did same thing, truck has 182000kms. I would rather Ave the extra distance og 1/2 a Def tank for it to reset, then 200 miles is cutting it close.
Old 02-18-2016, 11:14 AM
my_crib_too's Avatar
my_crib_too
my_crib_too is offline
Received 1,183 Likes on 364 Posts
Almost always keep mine above half full. Last added some when it was warm in fall. Last week when it was warmer, topped off with 1.5 gallons.
Old 02-18-2016, 04:45 PM
Nearly Normal Mike
Thanks folks. i will pick up some "new, blue, and improved DEF" now with genuine urea and available at my local DEF store.
I meant to do it today but my brain slipped out of gear after work.
If I remember correctly it goes into the larger hole, the one with the green cap. Or does it?????
Actually I have a large piece of pink duct tape over the DEF cap just as a reminder. I almost put some cetane booster into the DEF tank once!
It is rough getting old and I use all the reminders I can. The duct tape will have to do until they make a locking DEF cap. I also have to keep reminding myself that a GREEN pump does not necessarily mean DIESEL here in GA. If green is diesel it is a pure coincidence.
Old 02-18-2016, 04:56 PM
senix's Avatar
senix
senix is online now
I stay away from BP stations for the color of the fill pumps because of that.
Old 02-18-2016, 05:58 PM
capt caper's Avatar
capt caper
I see TSC has DEF now with a genetic brand beating Walmarts priceing.
Old 02-18-2016, 06:03 PM
senix's Avatar
senix
senix is online now
I will have to look at TSC! I know they carry the rotella T6 in 5 gallon containers.
Old 02-18-2016, 06:11 PM
Jmatthews's Avatar
Jmatthews
Jmatthews is offline
is a BAAAD MAN
Been there done that in my 7.3 once.
Old 02-18-2016, 07:26 PM
Larietpsd's Avatar
Larietpsd
Larietpsd is offline
Ford spout is the only way to go
Quick Reply: Yet another DEF question
