cheap lift ideas. Junkyard parts etc...
As you can probably tell from the title i'm on a budget. I want 4-5 inches of suspension lift without using blocks. I can get the ttb and radius drop brackets for around $175 on craigslist. I would try to find the front springs for less than $100. For the rear i'm thinking of getting junkyard f250 springs($36 for the pair) and flipping my stock shackles. From there I would decide whether I should remove the factory block. If the springs and shackle flip don't cut it I could get longer shackles. Would the rear setup work, I have seen a lot of differing opinions on the f250 leaves and stock shackle flip (not to keen on paying $200 for a shackle flip). What would I need to know about pinion angle etc, im not too familiar. Any tips or ideas would be appreciated. I can weld and do some light fabrication. Thanks
Received 3,101 Likes
on
I would use brackets and coilsprings from kits. I also have done the alignment bushings. I'm mostly asking about my ideas for the rear end, feasibility of stock shackle flip etc...
minnesotafisherman
21
11-06-2012 11:57 AM
fairfield86f150
05-21-2007 12:35 PM
