1995 f-super duty gear
I have I 1995 7.3 turbo it has a 5.13 gear in the axial with a 4speed with over drive my question is will a 1999-2001 f-450 or e-450 work under it or will it be better to do a new ring and Pinyan Pinyan gear and I pull a lot with it but at55-60 its 2500-2800 rpm I don't like that
Received 3,103 Likes
on
welcome to FTE.
the thing to remember with the F-SuperDuty is that you are trading speed for weight capacity.
if you tow heavy weights you need the gears and have to forfeit the speed.
if you put a 4.10 gearset in the rear, you will be able to go faster, but will no longer be able to pull the heavy loads reliably, and may see even lower fuel mileage because the engine will work harder to get the load moving than it would with the 5.13 gears.
on
big block power
23
03-06-2002 08:23 PM
