Ordering a 2016, what rear end?
3.55 Non-Limited Slip Axle Ratio
$0
3.31 Non-Limited Slip Axle Ratio
($3,426)
3.15 Electronic Locking Axle Ratio
($1,606)
3.55 Electronic Locking Axle Ratio
$470
3.73 Electronic Locking Axle Ratio
$570
3.15 Non-Limited Slip Axle Ratio
($2,026)
3.31 Electronic Locking Axle Ratio
($3,006)
I am going to also order a four wheel 900 pound pop up camper.
That will be the load.
$0
($3,426)
($1,606)
$470
$570
($2,026)
($3,006)
3.55. If you plan on bigger tires get the 3.73s. Doubt you'll ever need the elactronic locker unless you take your camper to the beach.
Also consider ordering the payload package. If you're pulling the pop up, you probably have the family or friends and a weekends worth of gear. The weight adds up quick.
I have the 373 electric axle. Love it ! I get 20 plus mileage highway driving. I get 17.5 and better around town. I pull a 29' flat bed trailer loaded 10,000 LBS. I also have the 5.0 and snow plow option. It is the XLT / FX4 Super Crew 5.5 box. Towing mirrors Black sport interior , Race Red. Go with the 3.73!
how e-loc works
how does fords e-locker work? does it engage when it determines it is needed? or is there a manual switch? My company vehicle is a f-450, with what I presume is an e-locker. I think it sucks!!! when you start spinning, the engine practically shuts down, then I guess the axles locks, then it lets you start again, AFTER ALL MY MOMENTUM IS GONE!!!! and max rpm is about 1500. is this the way the f150 works? if so, I will not be getting that option for a locker. I will go aftermarket
