99' E350 6.8l v10 - No Spark
was driving down the highway at about 55 the other day and she just quit and haven't been able to get her to pop or start since. Sprayed some starting fluid (i know bad) in the intake to see if i can get her to jump so i can rule out spark, but she didn't kick when sprayed with starter fluid. Pulled #1 coil pack and hooked up a test light and and no flashing when cranking.
One thing funky about this van is you have to Cram it into park a couple times to be able to get the starter to turn over the engine, but she turns over fine in neutral. Also I have never noticed a CEL in the van and when turning key to run or into start i dont see one.
I was fully loaded and RPM were high when running the van this trip also it was -23 with the wind chill. burr.
thoughts on where to check next, since i know i am cranking fine, but no spark.
ty all
lostislandguy
ty all
lostislandguy
You may have a blown fuse (no CEL light ?) or crank position sensor is acting up . Good luck.
