T-40 tamper-Torx
T-40 tamper-Torx
yo,
Get a small chisel/punch and knock the "security" pin off then use a cheaper set of reg. Torx sockets; or Sears sells the set for $20.00; then there is e bay if you're not in a hurry or mail order for cheaper sets;http://www.cvfsupplycompany.com/tototososeto.html
T-40 tamper-Torx
I find it odd that Autozone stores in some parts of the country stock the T-40 tamper-proof bits right out in the aisle and others don't. Every Autozone in St. Louis and surrounding "burbs" that I've been to has them hanging with the rest of the tools in these little test-tube-like packages with a black plastic hanger at the top. They are even marked as being "tamper-proof Torx". If anyone wants one I'll be happy to run to the Autozone here...mine only cost me about $3 or 4. Even the punch operation will take longer and cost more....if you don't already have the punch. Oh well, good luck guys.
T-40 tamper-Torx
Hard to come by because they are high theft item. After I found a set at Advance went to AutoZone and they sell them individually. At Advance they are in the tool aisle first peg all the way to the left in every one I have been to. AutoZone had them hanging by the sockets.
T-40 tamper-Torx
I have NEVER put more than four bolts back in the top. Two long ones at the front top corners and two short ones at the back lower corners. Never had it leak, squeak, or tweak on me. Takes about five minutes to reinstall the hardware. Oh, and the interior trim? Why? The top comes off too often to bother with all those little plastic cosmetic plugs.
