fuel problem
fuel problem
It has a red reset button. You can also pull the electrical connector near the tank and check for continuity on the two heavy wires. Should be the pink/black and black wires. The flow is battery > fuse > relay > inertial switch > motor > ground. And you can always hit the tank first. That can temporarily unstick the brushes in the motor.
tennesseecoalroller0
01-01-2012 03:08 PM
cajunbronco
06-16-2002 09:56 PM
