New Ball Joints. No Return to Center
Me and a couple buddies replaced the upper and lower ball joints on my 03 F250. We noticed the spindles were quite stiff after installation, but didn't think anything about it.
Test drove a block. Felt fine
Then I took it on a 30 minute ride back home and WELCOME TO THE OCTAGON!
Absolutely zero return to center, no tracking, there wasn't even a center. It was going right or left. It whooped my butt.
I got up this morning and greased them and it is WAY better. The truck is actually driveable now. It may need an alignment, but there's a center and for the most part it returns.
I posted this to say if you replace them and the spindles are stiff, grease immediately and save yourself some headache.
If you have a tire shop do this work, and have this issue, before taking it back for castor shims, a new steering gearbox, or anything else.....climb under there and grease your ball joints!
The following users liked this post:
Something's still not right. It tracks better and stays centered if you keep it there, but bump the steering and it's going that direction....the truck does not help you stay straight at all.
After changing lanes or going around a curve you must manually center the steering to straighten the truck. The truck doesn't dart or wobble. It simply will not return to center
- Previously with worn ball joints, there were zero issues. Truck drove great
- After installing ball joints, spindles were extremely tight
- The truck had no center at all after installation, it was either going right or left..period
- After greasing ball joints, there is a center and you can drive the truck straight, but there is no return to center
- Used Oreilly masterpro ball joints....other option was Moog for twice the cost...both offer lifetime warranty
May have tightened top ball joints first, but this issue doesn't seem like anything at all is too loose....too tight still if anything....what happens if alignment sleeve is unseated? no caster?
When you torque them in the proper sequence, tightening the top one takes a little bit of load off the bottom one (or something like that, but it works).
I'm willing to bet that the joints were installed with too much pressure, causing the body of the ball joint to distort and causing this. I have seen it too many times. People thinking the joint isn't seated and pressing them with tons of pressure.
I ALWAYS freeze the ball joints, heat the knuckle and always always always use some bearing grease on the body of the joint during installation. They just about fall into place and are operationally perfect every single time.
