2001 ford expedition blowing cold air out in front and rear vents.
I googled the price of a heater core. Turns out theres 2. 1 for the front and one for the back. I was told since both are blowing cold air its not my blender. Where do i look next? Do i check my thermostat or for aor in the system. Just bought it and have 2 kods need to gwt heat working. I have noticed that the front blower doesnt seem to run as fast ehwn set to the hotest setting. If o turn to cold it speeds up. Does that help diagnose anything regarding it only blowing cold air?
When the engine is up to temp carefully feel the heater hose where it comes out of the intake manifold to see if it is hot.
There is probably a restrictor inside the hose a couple of inches from the intake that is held in place with a crimp clamp, is it hot after that?
Next is a vacuum actuated heater control valve that shuts off coolant flow, is it hot after that?
QuadVan
15
01-16-2005 04:58 PM
