Compression fittings Aluminum only??? - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Log In
Old Yesterday, 05:04 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is offline
FTE fan
underthebridgejim has a spectacular reputation.underthebridgejim has a spectacular reputation.underthebridgejim has a spectacular reputation.underthebridgejim has a spectacular reputation.underthebridgejim has a spectacular reputation.underthebridgejim has a spectacular reputation.underthebridgejim has a spectacular reputation.underthebridgejim has a spectacular reputation.underthebridgejim has a spectacular reputation.underthebridgejim has a spectacular reputation.underthebridgejim has a spectacular reputation.
Im working on some plumbing using AN fittings and have repeatedly come across where it says For aluminum tubing only when it comes to compression fittings.. I even asked the summit tech dept. and got no answer. I don't understand why you cant use a brass olive on steel or a stainless steel tubing. I did end up using one on my tank to fuel pump line as there is no pressure on the inlet side of the FP. But now Im going from the SS trans cooler line which Im told is a max of 50 PSI. Ideally what I really need is a 1/4" female inverted flare to 6 an fitting. 4,5, an or so would work (I could use reducers to get the 6AN), but after a solid hour on Summits tech support line who could not find my ideal fitting. So This brings me to using either a IFF to hose barb , which I have, or cut off the IF end that came on the cooler lines and use the compression fitting which I also have. Does anybody know why they say tat a compression fitting is to be used on aluminum only, thank you guys for any input. PS I did see a fitting that used a rubber sleeve that goes over the flare or bubble flare on the tube end that is part of a tube to an fitting. cool beans right, but I cant for the life of me find where I saw it last week. Bummer. OK enough of my ramblings, thanks again.
__________________
Jimmy 1950 F-1
Old Yesterday, 05:29 PM
artscott61's Avatar
artscott61 artscott61 is offline
artscott61 is starting off with a positive reputation.
got kicked off don't have time no no NO
Jim sometimes the best bet is to go to a fleet service dealer as they have all the fittings or find a really good hardware store and not lowes or home despot they only have fans and washer and drier combo's. Besides that they really suck on service. No offense to anyone but that is the way it is with stores like that.
Old Yesterday, 06:22 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant futureALBUQ F-1 has a brilliant future
I could understand that a brass olive might not bite into a SS line, and you'd have to use a Swagelok on it. But I've used brass fittings on steel lines many times.
__________________
Ross
1952 F-1 Flat V8 3-on-the-tree, MSD, Rochester 2G, Red's Headers
"Never attribute to malice that which is adequately explained by stupidity" -- Hanlon's Razor
Old Yesterday, 07:35 PM
FTE fan
ART , I have to show my ignorance once again but what would I look up to find a fleet service dealer? What type of fleet service, auto, truck?
Ross, OK I see where SS mite not give the needed bite, I thought it might of been the fact that they were two dissimilar metals. And Ill look up Swagelok, I had never heard the name B4, but will do some research.
There is so much I don't know about, and Id be dead in the water with out all you guys. So thank you very much. FTE Rocks on!
__________________
Jimmy 1950 F-1
Old Yesterday, 07:48 PM
ALBUQ F-1's Avatar
postin' fool
Swagelok isn't something you want to use, it's a very expensive system. Their "medium pressure" line is good for up to 20,000 psi....
But you can see how it provides a lot more bite in SS than an olive.
Click the image to open in full size.
__________________
Ross
Old Yesterday, 08:07 PM
FTE fan
10-4 on that Ross. If Im unable to find an all threaded together solution, Ill probably go with the Inverted flare to a hose barb set up. IT wont be visible, (except I will know its there).
__________________
Jimmy 1950 F-1
Old Yesterday, 08:16 PM
artscott61's Avatar
Jim in my area we have a shop called Fleet Pride they handle all truck type parts make hydraulic fittings and a lot of tube fittings. Like Ross said swagelok is very expensive and over kill. Go to your local hydraulic fitting house and ask for a catolog of their tube fittings it will have most everything in it plus it is educational and free. Parker, Weatherhead or Gates has them.
Old Yesterday, 08:27 PM
FTE fan
Quote:
Cool, Im pretty sure we have a hydraulic shop in the next town over, thanks for that clarification. I always like learning new things.
__________________
Jimmy 1950 F-1
Old Yesterday, 08:33 PM
49fordv8f4's Avatar
49fordv8f4 49fordv8f4 is offline
49fordv8f4 has a good reputation on FTE.49fordv8f4 has a good reputation on FTE.
Jim, Speedway has 1/4" IFF female to 1/8" male pipe thread. I believe Aeroquip makes a -6 AN to 1/8" female pipe thread. I could check my Aeroquip hose and fittings catalog tomorrow and get you a part #.
Mark
__________________
  • Mark
  • '49 F4, Script bed with Galion Hoist, Mercedes 5 cyl Turbo Diesel, project
Old Yesterday, 11:26 PM
FTE fan
Thank you mark, I do still have the 1/4 iff to1/8 npt that I used on the original hard line to radiator conection, and also have the 1/8 to an 6 fitting , however the threads don't match pitch differences. My laptop just crashed, so it may be a week or two to get back to you. .I hate when this happens, I'll try to borrow this tablet again to get back on the board.Thanks again , I know that took a lot of looking, and I really appreciate it. I gotta give back this laptop now. RockOn
__________________
Jimmy 1950 F-1
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
