Demco Slider Hitch (pn 8550024)
Anyone use this that has the factory prep package? If so, I have a question. Being a slider hitch, do you have to be perfectly straight to hook up & unhook from it? I know some brands of hitches are more finicky than others about how straight on you have to be. Just wondering how this one is, straight on, or little fudge room.
The Demco is known to need a very straight hookup angle based on reports on all the RV forums. It's a nice unit despite that. One other thing to consider is that it is 1.5" taller at each of it's settings than the Reese Elite or B&W. So, if you have an already too tall SRW (which is the only reason to have a slider), you'll have a tough time getting many RV's level and not nose high.
Thanks for that info. The video I had seen on the hitch didn't have the metal rails on both sides. They have adjustable rails that you slide and lock into place once it was hooked up. I thought if that was the case, I could hook up at an angle, pull forward to straighten out, then set those rails. I don't consider that a deal breaker anyway, I was just wondering how it was. Thanks for the info.
Wouldn't get the full angle you needed in the first place. You'll see what I mean once you get it. Either way I like it no complaints.
That makes sense what your saying. In my mind I was thinking something different, but what you said makes sense now. Another question for you. Do you ever take yours out or leave it in? I know some hitches you can take out in two sections, like a pin that releases the hitch part, then you take out the rails separately, or is this one all in one?
Never taken it out, never had a need too. But you can take the top off, it has a pin the holds it in place with the base then you have the whole base left that is held by 4 pins; one at each corner. Once I get my cover I'll probably take the top off since it will probably not clear.
I've read where people leave their hitch on the kingpin when not in use, but I wouldn't want it sitting in the weather. I'm just gonna get a cherry picker from harbor freight for $200 and use it for removing the hitch and putting it back in. I'll just store the hitch in my garage on a furniture dolly so I can move it wherever. It sounds like the head will detach from the base. I'm not expecting any severe angles, just going to reposition where the trailer sits at my house. Where my current tongue pull sits will be too much angle for the 5er to hook/unhook without hitting a tree or fence. But I can move the trailer back further and have a straight shot at hooking up.
