Ebay catch can?
All the catch can's I seen on FleaBay were 3/8" or 1/2" outlets and on our trucks I do believe it was 5/8 hose it might of even been larger than that. You really wouldn't want to restrict down to that small. I myself made a catch can since all the cheap ones were the wrong size and the ones that would work were out of my price range.
Or just go to air with your CCV but that stinks .
Here is what I came up with made out of PCV and it helps but not a total solution but about $20 I'm pleased. It helps and keeps the crank case pressure at a negative psi. Home made CCV catch can with drain and plumbed back into intake Mind you I am sure there might be a better way but I built mine off of what I read about others doing this and Utube ideas.
There is alot of info out there. Here is one
https://www.ford-trucks.com/forums/8...questions.html
lvin4jc
19
04-27-2011 11:09 AM
tptrailblazer
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
22
05-13-2008 11:37 AM
Texas Outlaw
08-02-2007 03:24 PM
