Pro Comp ES1000 Shocks...
Here's the deal... I am lifting my 2000 Excursion using Pro Comp's 22210 / 22415 springs with 315/75/16 tires and was looking at different shocks. Does anyone have any FIRST HAND knowledge/experience with the Pro Comp ES1000 shocks with this method lift? Any reasons NOT to use these? I used the search function and didn't come up with what I was looking for. Be Blessed!
Pro Comp 124508 ES1000 Series Shock with Black Boot
Pro Comp 132000 ES1000 Series Shock with Black Boot
this is what 4 wheel parts says fits with 4 inch lift
Good point.
Both of those are a little more than I initially wanted to spend. Hoping to find something a little less with not too much compromise on the prod.
Anyway good luck, report back! I've been wrong before...
Bilstein 33 185545 Shock Absorber | eBay
This guy has THE best prices, and good service.
The es1000 is valved to replicate the OEM shocks ride quality. so it is going to be on the lighter side, It is a good twin tube replacement shock that is popular more for its cost then performance. Quality wise they are as good as any other twin tube shock you are going to find. Oh and yes I have owned them in the past.
If you wanted to go with a mono tube shock that is valved a bit stiffer then stock consider the KYB monomax. About $55 ea.
KYB Americas | MonoMax
