Ok just want to confirm this indeed stock air box. I have 6637 on truck now. Going to Chicago in a few weeks and may grab new filter and install this back.
I had bent washer so tried it to tighten the lid up. Helped a bunch
The AIS (stock on the 6.0 BTW) has a much better seal than the stock air box. It flows much better than the stock 7.3 box. And is much quieter than the 6637 filter. No, the AIS filter will not fit in the stock 7.3 air box.
Now I'm getting the picture ha ha. AIS is rounded where original is squared off. Original has two clips and tabs for alignment, AIS just has four clips and no tabs.
A dirty 6637 will flow a lot better than a new filter in the stock box. I while back I played around putting the stock box back on before replacing my dirty 6637. What a shock with how anemic the truck was. The stock box and filter suck!
The main issue with the stock air box is not the limited air flow. It's the fact that it doesn't seal well and can allow dirt in ruining the turbo and engine. If you're careful with it, and aren't running hot tunes, it really should be just fine, assuming it ain't leaking.
Is this stock box??
To accurately answer this question, yes the AIS is stock, in terms of being a Ford product, but no it's not as far as it being an upgrade to the square box intake, that most people will go to, or if more is required the 6637 filter (I think that is the number)
