Hello, I have 2006 f150 4x4 when i put it into 4 hi go's in fine locks start driving hit the gas hard jumps out of 4 wheel drive cost go's back in? make clunk Sound when it jumps out
With the AC or heat on the dash vent setting dose it switch to blowing out the defrost vent on the dash under hard acceleration? If so it would indicate a vacuum leak which in turn would let the vacuum applied 4x4 hubs disengage.
My brain was stuck in Super duty, I believe the F150s disengage with vacuum. You might check the electronic vacuum valve for the hubs to see if it's leaking A slight vacuum to the hubs in 4x4?
