6.0 Rough Idle/Start When Cold P0270/P0271/P0272/P0277/P0278
Hi all,
I'm new to diesels. I just bought a 2004 F250 with the 6.0 V8. I have the high and low circuit, contribution codes on cylinders 4 and 8. I've only had the truck for a few days but I've been reading a ton. The symptoms are hard start, rough idle/shaking, no power when cold. When it heats up and I'm over 2000 RPM it seems to be just fine. Even when hot and below 2000 RPM it does ok. I've check the FICM. It reads 48V with key on and 48V running. My plan is to do the following:
Change the Fuel Filters
Change the oil filter
Change Air Filter
Change oil with 5-W30 synth and I have both Hot Shot/Rev-X
If that doesn't work, I'll replace the two injectors.
How does that sound. Any help is appreciated.
Change Air Filter
That dealer/person is very mis informed on the 6.0. I've had mine since brand new in 2005 and since I've switched to syn 5 30 the injectors love it and it runs better than ever. I would even advise a new 6.0 owner to run it and I would bet that most anyone here would.
5-30 is too thin for these trucks.
You want to run a diesel rated synthetic 5w-40 oil for the best performance of your injectors. I personally use rotella t6, but any synthetic diesel oil of that weight will work well. Everyone has their own favorite, but the rotella is easily found and is pretty well priced at walmart and online, so it is a popular choice here.
If you are having rough running while cold, but not warmed up, that sounds like classic stiction to me. I have heard of good results with archoil for that. If the synthetic oil, new fuel filters and an anti-stiction additive (archoil, rev-x, hot shots) don't help much, some new injectors may be in order.
Good luck and congratz on the new truck.
Hi all,
Change Air Filter
Change Air Filter
