Crew Cab Bench Seat photos please!!!
Can someone with a Crew Cab OBS please take photos of your front and rear seats? I need to match up a few I found to replace my front and rear seats. My front is defiantly not what was supposed to be in there and the rear is gone. I need factory setup not bucket seats.
Preferably years of 1994 and anything the same as that.
Front and rear seats are the same, I just pulled the rear seat out of my crewcab and bolted it into my reg cab, used the factory holes and bolts....
If anything the front seat will be different as it doesn't need to fold forward like the rear would to gain access to storage.
Yes, there all the same seat, reg cab, crew cab front and rear.... I've swapped them around, they all fit.
The ext cab seat is a different animal, the mounts are different because the floor is different. come to think of it I don't think I've ever seen an ext cab with a bench seat......
Well looking at the mount holes for front vs. Back I do know the rear has a arch as in floor bracket not level. The front seems to be level. I would have to snap shot my setup but I'm sure you get the idea.
Okay so just to be clear regular cab is the same as crew cab but obviously ext cab there is no bench seat for the rear.
Guess the only difference is cab size spacing but the seats are all the same. Good to know!
Bronco front and Super Cab front are the same as each other, but different from the regular and crew cab seats.
edit: apparently you edited your original post after I quoted it, but it's still close enough that my answers still apply.
That's been claimed by some members, and spread around the forums. Funny thing is, GM came out with what they called "extended cab" trucks in the '80s. Ford had the Super Cab and Dodge had the Club Cab in the mid '70s ('73-'74-ish). I distinctly recall people referring to the Ford and Dodge offerings generically as "extended cab" trucks during that entire period BEFORE GM came out with theirs. I guess we were miisusing a GM term even before they coined it.....
"Extended cab" may have been a localized generic term. I certainly can't say what words everyone, everywhere used to call it. Kind of like "canopy", "cap", "topper", "shell", "camper" or "camper shell" all meaning the same thing but not all being used in all areas (and I'm probably missing others). But the fact does remain that no manufacturer other than GM ever called that style "extended cab", and Ford (who made one about 12 years before GM) has always called it a Super Cab.
Still, I'm getting soft in my old age so I will admit that all Ford guys do know what you mean when you say "extended cab" and I've "mostly" stopped correcting it. I only mentioned it in this thread because in the post I quoted (prior to it being edited) Irish seemed to be saying that he understood that a Super Cab rear bench wouldn't work, while an extended cab didn't have a rear seat. I was pointing out that they were two different names for the same truck.
Although, while I'm rambling on, I saw a thread recently where someone was talking about their SCLB F-350. "SC" means "Super Cab" to people that speak Ford and don't like typing long words, but F-350s of this vintage never came as Super Cabs. So I'm thinking they probably meant a single cab, which I think is Toyota-ese for what Ford calls a Regular Cab. So it is sometimes less confusing when everyone uses the same terms, and since this is a Ford board it might make sense to standardize on the Ford terms.
Bu again, everyone knows what Extended Cab means.
