FICM issues and Tuner problems
Hi my name is John. I recently was having cold start issues and sputtering under high RPMs. I have a hard code P0611 code on my Edge Evoulution tuner. I decided to have MY FICM rebuilt by All Computer Resources. I upgraded it to the 58V FICM. Before I took mY old FICM out I returned my tune back to stock. I installed the New or rebuilt FICM and tried to set my tuner on Extreme. After a few minutes my tuner required an update and would not tune to the desired setting. I started my truck and it was about 30 degrees outside. It was a really rough start and I am, having really low power. I also still have the P0611 hard code. What should I do? I am pretty new to diesel motors.
BBB in Miami has several complaints for All Computer Resources. Other than that I know nothing of them. One of the most highly thought of repair shops for your FICM is FICMRepair.com Talk to Ed and he WILL get your FICM repaired correctly and he will also explain to you why you don't want/need a 58volt FICM.
John
04F-250mark
02-19-2010 11:56 AM
