Aftermarket fan?
You do not want a flex fan. They have been known to come apart. Just type in flex fan failures on google.
I would either just find a stock type fan or upgrade to a severe duty clutch fan if you need more cooling capacity.
I always run the stock fan blades. They worked for the first 50 years...
But, I'm sure if you guys in the warmer climates add A/C then it could run a bit hotter since the radiator is typically at least partially blocked by the condenser. Make sure your radiator is clean inside and that the engine block isn't full of crud. Two commons sources for overheating that a fan blade would only be compensating for.
Agree!!!!!
+ Supposedly the curve blades are quieter but, in the aftermarket world 99% of the e-fans are junk in terms of design & quality IMHO. The OEM units flow anywhere from 50% to 200% more CFM than the "Hi Perf" aftermarket units, last for years in real world daily, all weather use and are quiet- and are less expensive in most cases!
I bought (2 years ago) a replacement assembly for my wife's 1997 Cougar Sport (V8) (the bearings in the e-motor were starting to whine).....the entire assembly including the shroud was $120 with tax (I bought the entire assembly because the motor itself was $80).
You will also hear/read about people having issues/concerns with their engines running warm/hot, once it is really verified and there are no mechanical issues, 99% it can be traced right to these HP Aftermarket fans.....those using oem units- I have never in 20 years heard of an issue related to them in any way in regards to cooling.
There are many on the market to choose from…..the V6 Ford Taurus fan (90-95 3.8L), If space is tight, the 95-00 V6 Ford Contour, 99-02 V6 Mercury Mystique, 99-02 V6 are flatter in design IIRR but if you don’t mind making your own shroud…..
Custom Electric Fan install - Taurus + Aluminum Shroud - Vintage Mustang Forums
Agree!!!!!
Here's one on eBay that looks very similar to the one on my 352. I might check a number stamped on it if the seller were willing, but seems pretty close.
Used 64 Ford Full Size 352 390 Radiator 4 Blade Fan Blade C5AZ 8600 B | eBay
Depends on what engine you have and what you do with your truck.
John
Just don't let it run too cool. I like to see minimum 180 to keep moisture out of the oil.
