Hello need diagnostic help
I have an 86 351 F250 and something went wrong. On the highway steam started to crep through the dashboard and fogged up the inside of my windshield and side windows. The steam was very moist and my hand would get wet wiping it away. I noticed there was little to no heat in the car.
I had to roll down my window and drive with my head out so I could see and exit the highway safely. Once I stopped the truck I saw orange liquid dripping on the passenger side somewhat by the door towards the back.
Under the hood I can't locate the leak. I narrowed it down to the heater core, heater hose or radiator hose going bust. What do you think? Thanks
I think so. On my air adjuster on the dash on the far left next to the off button it says A/C with a bracket pointing down to two position you would slide the lever over to. I guess it means it has air conditioning? I'm not totally sure.
There's a difference between factory air vs dealer-installed air. But, it sounds like you have factory air if the slider has a position for A/C. That's good since you can pull the glove box door, pull the glove box liner, remove ~8 screws, and see the back side of the heater core. Remove the heater hoses and the core comes out. Install a new one and new hoses, refill and bleed the system, and away you go.
BUT! There are several different heater cores and not everyone that is selling them is telling the truth about what fits. So, go to your local auto supplier with your core in hand, and buy one just like yours.
There are two hoses, as shown below. The first pic is a closeup showing where the the heater core sticks though the firewall and the hoses connect. The second shot shows the length of the hoses. If you're aren't realitively new you should consider replacing them as you will probably tear them up getting them off the heater core.
