no power and white smoke out exhaust.
Ok, I am having a problem with my 1992 ford f250 with the 351 and 5 speed manual. It has no power and when i start it up and hold down the clutch and hit the gas it bogs down and blows out alot of white smoke out of the exhaust. It will only go to 45 mph.
It has not cat on it, fairly new exhaust, It drove fine in the morning but when I hoped into it to head home it wouldn't let me go no more than 35.
Does this white smoke dissipate rapidly?
If so as previously stated its coolant blowing out the tail pipe.
If its actually smoke it doesn't rapidly dissipate I believe brake fluid burns with a white smoke, a fluid leak into the brake booster could be a possibility but you'd also have to be suffering brake issues. Such as hard to push the pedal down, little or no power assist.
If the diaphragm is ruptured it might suck brake fluid from what is or was an otherwise good master cylinder due to the amount of vacuum put to it.
Doesn't take much coolant to produce white smoke/steam, depending on how long ago it started the coolant may not have noticeably gone down yet.
That is the most likely cause for what you describe.
A rich fuel mixture creates black smoke, burning oil creates blue smoke.
Water/coolant creates what looks like white smoke when it goes through combustion and is blown out but it is actually steam not smoke. Steam rapidly dissipates to nothing very quickly once out of the pipe, smoke from burning oil etc does not rapidly dissipate so its pretty easy to tell the difference between smoke and steam.
What does this smoke smell like?
