DIY wvo system for sale - Ford Truck Enthusiasts Forums
Old 02-09-2016, 03:39 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
Got out of the game a month ago. Unfortunetly, I dumped my filtering system at t junkyard..(2-barrell w/ centrifuge)....anyways, sysem still in truck, using it as a spare 15gal so system stays running. However, now I need the bed space (std bed). Message me if intested with email. I provide pics....in the So-Cal area
Old 01-04-2017, 03:50 PM
Y2KW57's Avatar
Y2KW57 Y2KW57 is offline
Y2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputationY2KW57 has a superb reputation
Why did you "get out of the game"?
Old 01-09-2017, 10:43 AM
timmyboy76's Avatar
Tell you what, Y2... It was the next best thing, to sliced bread. Unfortunately, and if you travel down here from the high desert, you'd see the mayhem at 91/15. Because of that, I decided to sell the home and move closer to my daughters school, saving me/us about 500 miles a week and or insanity of not having to wake up at 4am now **** b in traffic for 4hrs..to/from
Old 01-09-2017, 01:07 PM
Y2KW57's Avatar
Ah... so it sounds like you lost both the yard space to process the oil, as well as the need to drive as much that justified the time spent collecting and processing the oil?
I am trying to move in the opposite direction... away from town... and getting more yard space. The centrifuge would have interested me, but you already junked it.
When/if I move, and if I can find a steady source for WVO stock, it seems like a centrifuge would be a good idea to employ as part of the process. Unfortunately for your sale, I am not interested in any inbed tank, as I plan to use an under chassis mid ship tank for WVO that would compliment my existing stock 40 gallon aft axle tank for regular diesel.
I was just curious why you got out of the game... because I wouldn't want to get into a game that most people leave after they've tried it for a while. I want to know the good, the bad, and the ugly before jumping in... to avoid having to jump out so soon.
Old 01-15-2017, 02:34 PM
timmyboy76's Avatar
PA-Biodiesel was the centrifuge company I used. There "kit" containing both pump with incorporated gearator(something like that), and there 55gph centi. Y2, after all said and done, I could've sold it back to restaurants, because of how clean the end result was. And I had some Purdy knarly oil..
When bleeding pressure from centri, I diverted the oil to a firesprinkler, which in turn, had a great spray pattern to diminish any potential trapped water, into the air😉.
Ran a 2-tank system, with a 3rd tank in backyard for settling purposes. Brought oil into first barrel, heated it up while pushing through 50/20/10 micron housefolters. Then centrifuge once at 80ish degrees for approximate 4hrs. Let settle/cool then finally pump the 10/2 filters.
. Sold in bed system last April....
Old 01-17-2017, 12:55 AM
Y2KW57's Avatar
Thanks for your informative insight on your oil processing. Reps sent!
B&W Companion Hitch for Ford with Factory puck system REVIEW IronCobra 6.7L Power Stroke Diesel 18 02-22-2016 08:17 PM
Full fuel system rebuild. What should I do? EasternJU87 1987 - 1996 F150 & Larger F-Series Trucks 1 12-05-2015 01:41 PM
53-72 long bed tailgate on 50 f3 Poes 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 08-12-2015 09:48 AM
Bed replacement Shane Carruth 1961 - 1966 F-100 & Larger F-Series Trucks 6 01-23-2015 07:12 PM
holes in the bed jda1961 2009 - 2014 F150 12 04-12-2009 03:29 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
