97' f250 hd, left fr inner axle shaft
Old 02-08-2016, 08:55 PM
Orourkebrad1976's Avatar
Orourkebrad1976
Orourkebrad1976 is offline
Hey fellas, while plowing the other day in my 97 f250 hd, I busted the left front axle u-joint, and the inner shaft ears are messed up enough that I won't get the new u-joint caps into it without doing some grinding or filing to get the ears back to round. Any thoughts about if I should or shouldn't try to salvage it? And any of you guys have a left front inner shaft for a Dana 50 ifs you'd want to get rid of?
Old 02-08-2016, 09:13 PM
LeoJr's Avatar
LeoJr
LeoJr is offline
Where are you?
Old 02-09-2016, 05:50 AM
Orourkebrad1976
Northern lower Michigan
Old 02-09-2016, 07:27 AM
LeoJr's Avatar
LeoJr
LeoJr is offline
broncograveyard.com is a well known source...thought they also carried used items but didn't see any on their website...may be worth a phone call.
I have one but there is bound to be one closer.
I wouldn't hesitate to get a salvage shaft...you already know what a bad one looks like so I suspect you could spot any defects. I think the driver's side inner axle just pulls out once the spindle is removed?
Old 02-10-2016, 08:27 PM
Orourkebrad1976
Thanks fellas, I called several salvage yards yesterday looking for a used shaft but didn't have too much luck, so I just fixed mine with a little elbow grease.
Old 02-11-2016, 12:23 PM
Oscello's Avatar
Oscello
Oscello is offline
I also have one but I'm not much closer.
aidandj
03-03-2014 12:46 PM
fatboyjon
06-12-2010 12:06 AM
cabloom300
04-30-2010 03:33 PM
cabloom300
03-15-2010 11:34 PM
Quick Reply: 97' f250 hd, left fr inner axle shaft
