Want to fill the body clad holes ? Easy as Duh !
Like many peop,e I removed the body cladding years ago and while the holes in the rear quarter panel bugged me I just always chalked it up to bugging me less then then the body cladding. I had seen a few excursion with small panels and over the years I have kept an eye out for them on exe's being parted out and get on eBay but never saw any. Until a few weeks ago. Only problem was the wanted to much for them. So I finally got around to seriously looking for them.
Turns out they came on the 2000 XLT model and low and behold Tascaparts.com had them available from the factory !
Before
Before
Edit. No. The 2 holes in the fender lip use the 7mm body screw with the large washer, the 3 rivets are used at the bottom edge of the rocker panel.
The rivets are used through out the excursion and there is only one size
100 Pcs Plastic Push Type Rivet Retainer Fastener Bumper Pin Clips for Ford | eBay
Ford also uses Christmas trees to attach panels such as the rubber air skirts in the engine compartment, they are also widely available.
speed_is_addictive
12-16-2016 10:45 AM
hatemakings/n
General Automotive Discussion
10-07-2006 10:43 AM
mike.norton53
08-29-2005 10:33 PM
