Interior Light Wire
I would just use the running board courtesy light wire that is attached under the truck to each side of your frame. That wire will supply 12v when the doors are open or the dome light comes on. I believe you can purchase a Metra connector 72-5600 that will plug right into this capped plug on your truck. This is actually what I am planning to do in the spring when I wire my bed lights.
Here ya go, I found the post with pictures:
https://www.ford-trucks.com/forums/1...l#post12318595
