cam sensor wiring
Old 02-08-2016, 11:20 AM
willy j's Avatar
willy j
willy j is offline
cam sensor wiring
I was hoping maybee someone could tell me what the part is that the cam sensor wiring goes too, I see the harness branch off to a part on the lower front of the block (kinda looks like a temp sensor) on drivers side. I appreciate any advice. Just threw a 1309 code and would like to do some homework. Thanks all
Old 02-08-2016, 05:13 PM
willy j's Avatar
willy j
willy j is offline
dtc p1309
Originally Posted by ***** j
I was hoping maybee someone could tell me w, hat the part is that the cam sensor wiring goes too, I see the harness branch off to a part on the lower front of the block (kinda looks like a temp sensor) on drivers side. I appreciate any advice. Just threw a 1309 code and would like to do some homework. Thanks all
Well I think I might have figured it out. Cylinder head temp sensor, if so would this set off the 1309 code? I dont know, still digging
Old 02-08-2016, 06:52 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,680 Likes on 1,357 Posts
I found this; P1309 FORD Misfire Detection Monitor Not enabled | AutoCodes
What are you working on? Sounds like the cam sensor has to be setup and positioned properly or it will give that code.
Old 02-08-2016, 07:20 PM
willy j's Avatar
willy j
willy j is offline
2000f150 v6, camshaft synchronizer is 3 yrs old (Dorman) I believe the sensor is mounted right on the top of the synch. Good thing is the synch has a lifetime warranty, is it possible that it was never positioned properly from the begining
Old 02-09-2016, 04:39 PM
willy j's Avatar
willy j
willy j is offline
Okay. Possible cause #1of the misfire detection code says faulty cam sensor, according to my sources it tells me that if I have spark then the cam sensor is fine and ignition coil is working. Cause #2 says cam sensor not installed correctly, im assuming it is since its 3yrs old and i just recently got the code. Cause #3 says to verify the cam sensor is synchronized. I cant seem to find a tutorial that can help me do that, before I continue with the next couple causes which dont sound too pleasing, I would like verify that the sensor is synched properly and im struggling with it.
Btw the truck runs great,two weeks ago I experianced a crank but no start situation for a couple days and got stranded, it eventually started and has been running since. This is why im here now. Thanks so much.
Old 02-11-2016, 05:33 PM
willy j's Avatar
willy j
willy j is offline
Well ive been doing alot of googling and research lately only to realize that not only was i steered in the wrong direction from the beginning by the AZ guru but I see now that I must look like a real fool now that ive proof read my posts here on this thread.
I was told by AZ that the cam sensor was mounted right on the top of the synchronizer and its not. The wiring I was wondering about literally does go to a temp sensor.........man I feel like a jack ***, sorry for wasting everyone's time though.
Old 02-13-2016, 07:27 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
Don't beat yourself up too much---that's why we're here!
Honestly though I'm sure most of us have also made similar mistakes. One of my all time favorite self-created sayings is: we learn more from our mistakes than our successes.......... After all the biggest part of life is learning what NOT to do.
Old 02-13-2016, 07:31 AM
willy j's Avatar
willy j
willy j is offline
Yeah your absolutely right about that
Sent from my SCH-I535 using IB AutoGroup
willy j
3.8 & 4.2L V6
02-07-2016 11:26 AM
bcaughhorn
1997 - 2003 F150
07-20-2013 02:46 AM
Roasted7
02-03-2013 08:07 PM
ltlrace
1983 - 2012 Ranger & B-Series
12-16-2003 06:31 PM
kentpsmith
Modular V8 (4.6L, 5.4L)
07-07-2003 09:08 AM
Quick Reply: cam sensor wiring
