T 98? - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Log In
T 98?
Old 02-08-2016, 10:10 AM
50f6's Avatar
50f6 50f6 is offline
50f6 is starting off with a positive reputation.
T 98?
I have a 50 F5 with a flat head 6 4 speed crash box, I have a line on a T 98 out of a 51 truck but it has no bell housing or rear mount on it, will I be able to use my old bell housing and mount or fab. my old mount to fit, I believe I have to shorten the drive shaft. Thanks for your info
Old 02-08-2016, 10:22 AM
49fordv8f4's Avatar
49fordv8f4 49fordv8f4 is online now
49fordv8f4 has a good reputation on FTE.49fordv8f4 has a good reputation on FTE.
The half bell on the T98 is different than the one you have on the T9. The hole for the bearing retainer on the T98 is larger. Everything else on the half bell is the same, you can bore the hole larger to fit the T98. The rear mount is also different. The foot is facing rearward on the T9 and forward on the T98.
Mark
__________________
  • Mark
  • '49 F4, Script bed with Galion Hoist, Mercedes 5 cyl Turbo Diesel, project
Old 02-08-2016, 06:44 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a very good reputation on FTE.38 coupe has a very good reputation on FTE.38 coupe has a very good reputation on FTE.
Mark pretty much nailed it. Here is a thread where he provided pictures to go with the description: http://www.ford-trucks.com/forums/13...-an-f-2-a.html
__________________
Fred Mills
38 Ford coupe project
49 F-2 pickup
53 Ford Customline sedan
Oliver 77 row crop tractor
Old 02-08-2016, 07:53 PM
49fordv8f4's Avatar
Thanks for posting the link, Fred. I thought that I had posted the photos but I wasn't sure where. I do have a couple of T98 half bell if anyone needs one.
Mark
__________________
  • Mark
Old 02-08-2016, 10:16 PM
38 coupe's Avatar
I may want one of your T-98 half bells. My Ditch-Witch transmission half bell is drilled for smaller dowel pins than are in the McBar 337-to-early-Ford adapter I have. Also, the Ditch-Witch half bell looks kinda ugly compared to the stock Ford unit. Depending on cost it may be more cost effective (the polite way to say cheeper...) to bore out one of the T-9 half bells I have.
__________________
Fred Mills
49 F-2 pickup
Old 02-09-2016, 09:24 AM
50f6's Avatar
thanks for all the help. would anyone know where I can buy seal, would van pelts have them
Old 02-09-2016, 09:50 PM
38 coupe's Avatar
Van Pelt will probably have the seal. If you have a good auto parts or bearing store in your area you can bring in your old seal and they can probably match it up.
__________________
Fred Mills
49 F-2 pickup
Old Yesterday, 06:53 PM
49fordv8f4's Avatar
The rear seal in the T98 is the same as the T9. The Ford part # for the seal is 01T-4813A. That number crosses over to a National part # 410308. My flange yoke on my transmission had a pretty deep groove worn in it from the seal so I turned the yoke down from 2.125" to 2.0625". Ford actually offered a seal with the smaller I.D. part # 01T-4813 which crosses to a National # 450307. The flange yoke, brake drum and brake band are the same between the T9 and T98 also. The linkage from the brake handle to the band is different though, the T98 is longer. There is no front seal in either transmission.
If you have a bearing supply house locally they should be able to supply the seal, the National number is a common one. Napa or your local auto parts should be able to cross the National number to their house brand. I believe O'Reilly sells National.
__________________
  • Mark
Similar Threads
Bell housing ID willys392 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-19-2015 02:54 PM
T98a mated to 289 greyhound 1961 - 1963 F100 Unibody 1 04-19-2015 09:25 PM
'95 F700 lpo clutch replacement jjqllc Large Truck 2 04-18-2015 10:05 PM
FE Bellhousing Question pimp2303 Clutch, Transmission, Differential, Axle & Transfer Case 2 08-18-2014 05:59 PM
390 FE Motor Swap sixtyonef100 1961 - 1966 F-100 & Larger F-Series Trucks 4 04-02-2014 09:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
