Hello
Hello
Good morning I have a question hopefully this isn't a stupid question I recently replaced the timing chains and timing gears on my 1999 Ford f150 I am Not sure if I put the crankshaft positioning sensor trigger back on my truck it wont start but if I use starting fluid it will attempt to start if that trigger is not on would it attempt to start thank you for any information my motor is a 4.6 Romeo engine w code
Does it back fire or attempt to run smooth?
As to if you put everything back on correctly...can't hazard a guess for yes or no. the only way is to take things back apart and double check timing is correct
BayleeWatson07
10-21-2016 05:02 PM
CO_87Bronco
05-31-2003 10:07 PM
