1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Bottle Jack Lifting Capacity?
Old 02-07-2016, 08:15 PM
Dave_Yuhas's Avatar
Dave_Yuhas
Dave_Yuhas is offline
What is the lifting capacity of the bottle jack that comes with the 2016 F-250 SRW? (I think it's 2 ton. ) If the information is in the Users Manual then it is especially well hidden. I'm carrying a 2,000 lb camper. Should I get a a 4 or 6 ton jack?
Dave Yuhas
Pacifica,CA
Old 02-07-2016, 10:13 PM
ufvj217's Avatar
ufvj217
ufvj217 is offline
about a month ago i bought a 20 ton one from Northern Tool. I wanna say it was 35 or 45 bux. i got it just to throw behind the seat in my dually, because i had a tire blow out a few months back and had a LOT of tile in the bed, and had no way to jack up the truck. luckily it was a dually and i drove very slow to a tire place that was right near me thank God, and even they had trouble with their floor jacks, they had THREE 2.5 or 3 ton floor jacks and barely got it off the ground just enough to change the tire.
i figured the new 20T would just collect dust in the back of my truck until needed, because for shop type work around the house (oil changes etc), its not exactly the fastest jack to use for maintenance work, but in the month i have owned it, i've used it a good amount of times believe it or not. i was removing my old driveway and i was at the end, where it meets the street gutter. i didn't wanna damage the gutter, so instead of jackhammering it etc, i decided to dig a hole under it, put a 2 by on the ground, and use the jack to slowly lift it and see what happened. it worked, and the jack lifted it without a sweat. great jack, just slow, like any bottle jack. i'd def spend then 40ish bux and grab one of those just to have so you never have to worry. they have 12T for a little less i think, too.
edit- here's the one i got: http://www.northerntool.com/shop/too...1777_200641777
Old 02-08-2016, 12:09 AM
davester250's Avatar
davester250
davester250 is offline
Yeah, threw the jack that came with my truck in a box and carry a 10T bottle jack. it's got a bigger base, so I'm more comfortable with it [i've had a F150 slip off a jack-all while doing a tire change...]. The stock jack feels like it's just good enough to lift the truck when it's totally empty.
Old 02-08-2016, 12:27 AM
ufvj217's Avatar
ufvj217
ufvj217 is offline
Yea i hate the base on the stock one as well.
Old 02-08-2016, 05:26 AM
Chuck's First Ford's Avatar
Chuck's First Ford
Chuck's First Ford is offline
that little Ford jack.. is only good if truck is empty.. and you have NO better one..
I have a 12 ton bottle jack... under the seat.
Old 02-08-2016, 09:14 AM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
I carry two 6 ton bottle jacks.
Old 09-15-2018, 01:22 AM
Fifty150's Avatar
Fifty150
Fifty150 is online now
Old 09-15-2018, 06:29 PM
Fifty150's Avatar
Fifty150
The jack that comes with the car is the last resort, and the worst option. With any car. Not one truck, Japanese or American, actually provides you with a good jack, or a jack that will work if you are carrying recommended payload.
Let's assume we are dealing with GVWR Class 2; Ford F-150, Chevrolet Silverado 1500, GMC Sierra 1500, Ram 1500, Toyota Tundra, and Nissan Titan. Forget about carrying 3000 lbs or towing. We;ll just say you have half a ton. 1000 lbs. Sure. Go ahead with that scissor jack with 1000 lbs of bricks in the bed. No bueno.
I would rather call a tow truck, than try to use that scissor jack with an F-150.
Norma stitz
11-13-2016 09:20 PM
mark996
06-02-2011 07:07 AM
texastech_diesel
General Automotive Discussion
12-02-2008 09:48 PM
mrc59
06-12-2004 06:05 AM
Jupiter Coyote
1997 - 2003 F150
04-20-2004 01:54 PM
Quick Reply: Bottle Jack Lifting Capacity?
