Data logging
Data logging
How many of you use the data logging on torque pro or dash boss? I finally got around to setting it up and it is nice. Especially with issues and trying to read data on the pid gauges ypu miss stuff. couple things i noticed. One is my ficm is wonderful. Never drops below 47. Next my battery volts koeo actually went to 10v at one point. Once started it will go to 11.5 for a few seconds then stays at 14 to 14.4. I thought that bit of data was interesting as i don't see the 10v part on scangauge or torque app as it happens so fast.
I just hooked up the Dashboss last week. Haven't messed with the data logging much yet. I read that you can e-mail it as well. It sure is a great option to be able to get a clear picture of what is going on and tackle issues as they appear before they become a bigger problem.
Didn't think about the smoothing.
But now with the Dashboss it seems like the graphing is already done. I just need to learn what to look for on the 6.0L's - I'm still learning. Maybe a thread on some stock PID graphs for comparison would be good..........
Also good for noticing changes over time.
I save all my data logs for every time I drive it. I plan on comparing a few of last years number with this years to see if anything has changed so slowly that I didnt notice.
side note I originally started data logging for the GPS and speed logs as a back up for when / if I get into an accident. Hard data beats what I say with insurance companies every time. Been in too many he said she said oddball accidents in the past.
From what I've seen I think DB is quite a bit better in the data logging area. I log trips also, but you have to set up what you want to log as a separate task in Torque -- it looks like DB you just tell it to log any real-time screen you have up, I think that is well thought out.
I port my logs to excel and do analysis of the data on spreadsheets...
Indirectly IF the system is working correctly. MAP and the EBP # can
tell you what it doing but like I said that is indirect. I'll try and post
the graph in the turbo test screen from IDS.
Sean <BR>
6.0L Tech Folder
Sean <BR>
6.0L Tech Folder
