Cold Starter?
Cold Starter?
I have a 2000 Ex with 105,000 miles. 10 Cylinder gas engine. Brand new battery. It has been finicky starting the past few weeks. Sometimes when I turn the key, I just hear a click. Other times it starts right up.
Last night I drove it and while inside for about 2 hours. The temperature dropped from about 30 to 20. It would not start at all. I went back for it this morning (temp is about 40) and it started right up 2 times.
So, does cold affect a starter? Any ideas?
Thanks.
Thanks.
Personally I've only had my X (7.3 mind you) down to the high 30's and low 40's, but we did spend two weeks in Colorado last year when it was down to 8*. Even then, it still cranked up - albeit begrudgingly.
The only time I've ever heard a 'click' referenced with an intermittent starter issue is when it's a bad ground. What happens when you try whacking the starter while someone cranks it when it acts up? If it fires right up, that's usually a sign of a bad starter. The cost to rebuild is typically about $10-20 less than buying a new one these days, at least that's what my poking around revealed when I replaced my starter last month. Ditched the 3-bolt and moved to the 2-bolt starter, WORLD of difference.
Bullet-Nose
03-11-2005 08:55 PM
