maf conversion
maf conversion
I picked up a 1994 f150 recently. It has a 5.8,e4od,4x4 with 3.55s and 33s. I noticed it has a maf sensor but is not hooked up. I looked up the vin and it was 5.0 truck. It has what I believe is a map sensor though. Would the 5.0 pcm run a 5.8 with a map sensor? I would like to know how to change it back to a maf system. I've used the search but I haven't had much luck finding info for my situation. I did get some wiring and pcm from another maf truck. Thanks for any help.
on
Start by swapping out the complete engine harness, MAF uses sequential injection while SD is batch fired, but before you button it up pull out the PCM and get the catch code off it, post that up to see if we can decode it to see if it is a MAF or SD PCM. If it is a MAF PCM then you need a MAF wiring harness, but if it's an SD computer then you need a complete SD harness and you also need to figure out if the truck was actually MAF to begin with.
PRIMERED79 SHORT BED
37
03-21-2020 09:46 AM
bearster18
Ford Truck Parts for Sale
10-30-2013 11:27 AM
TigerDan
06-01-2005 06:46 PM
