Do these wheels fit??
Anybody have any more info on these wheels? Seller says they are 17". Do they fit the Ex without spacers? I'm pretty sure I've seen an Ex or 2 on craigslist with these, I'm just trying to confirm. It seems like a good deal and I already have aftermarket 17" so I can just swap the tires and balance them and I'm good to go. I'd love to get rid of the aftermarket wheels. I think it's part of my 75 mph vibration issue.
Thanks in advance!
Thanks in advance!
It seems Tom is right on this one. I just did some searching and it turns out they are 16" from 99-04 SDs. So much for swapping my current tires. I guess I'm going to keep looking for a set with tires or a 17" rim. Did Ford make a 17" rim that fits the Ex or are we stuck with 16" or the Harley/Lariat 18"s?
The '04 H-D, Lariat, King Ranch and SVT 18" rims are the ONLY OEM rims in any size larger than 16" that are designed to work with our suspension geometry.
With the '05 pickup suspension changes that also included new bigger brakes the minimum size rim the '05+ trucks can run is 17" and I think the even newer trucks might be a minimum of 18". But of course those rims will have the later model backspacing that would require spacers to properly fit our EXs.
