1978 460 external to internal regulated alternator question
Old 02-07-2016, 09:42 AM
three.on.the.tree's Avatar
three.on.the.tree
three.on.the.tree is offline
Hey guys I have a 1970 ford f100 I put a 1978 460 out of an rv. It has a externally regulated alternator. I'm looking to put in a internally regulated alternator. Which years came with a internally regulated alternator that will bolt right up? Or do I need to buy after market?
thanks guys
Old 02-07-2016, 09:52 AM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
No need to go aftermarket. Grab a 130-amp 3G alternator from the salvage yard after reading the 3G retrofit thread linked in the Tech Info Compilation. It's the best $50 I ever spent for an charging system.
Old 02-07-2016, 10:13 AM
three.on.the.tree
What years came with 130 3g alternator, and will only an alternator off a 460 work?
Old 02-07-2016, 10:21 AM
HIO Silver's Avatar
HIO Silver
130G Alternators:
Two-holes in case.
94-96 Mustang 3.8 V-6
94-95 Mustang 5.0
94-96 Thunderbird 3.8 V-6 (non SC)
95-96 Windstar 3.0 V-6 (most are 3.8's)
93-96 E/F series Trucks/Vans 4.9 L6*
96 Sable 3.0 V-6
94-96 Cougar 3.8 V-6
90-95 Ford Taurus.
91-95 Mercury Sable
Basically:
  • Red/ Green (or Green/ Red) from the alt to the red/green in the factory harness.
  • Take the old large gauge Black/ Yellow and tie it into the + side of the solenoid.
  • Yellow/ White to large power stud on alt.
  • Alt power wire to + side of solenoid with 175 amp MEGAfuse.
  • Done! Drink a beer.
Detailed info in the Tech Info Compilation... Please use it!
Old 02-07-2016, 01:51 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
And your factory amp meter gauge will not work correctly or maybe not at all? I think I remember that statement being correct?
There is a guy off the web that does some kind of work/conversion to them to make it work with the 3 G upgrade.
Old 02-07-2016, 02:07 PM
HIO Silver's Avatar
HIO Silver
PA Performance has a modified VR that allows retention of the ammeter.
And here it is: 1G-3G Conversion (462802C) - PA Performance.com
Old 02-07-2016, 02:10 PM
77&79F250's Avatar
77&79F250
Thank you for that link, I knew it was something like that.
Old 02-07-2016, 02:12 PM
HIO Silver's Avatar
HIO Silver
10-4 Good buddy.
Old 02-07-2016, 10:24 PM
ZarK-eh's Avatar
ZarK-eh
ZarK-eh is offline
3g 90amp alternators are a decent upgrade as well. Don't always have to jump to 130amp... although that's what I did Lucked out and found a '96 truck with 130amp.
edit: The wiring requirements of the 90amp will be a smaller gauge wire than the 130amp, might be able to engineer a setup that uses the original ammeter.
ctubutis
'80-'86 HOWTO's
11-12-2023 12:34 PM
Jsek
11-20-2016 08:44 AM
sdetweil
06-13-2008 09:10 PM
docholiday72tx
Electrical Systems/Wiring
06-22-2005 07:39 PM
33bronco
1966 - 1977 Early Broncos
03-18-2003 01:48 PM
Quick Reply: 1978 460 external to internal regulated alternator question
