Use of Cetane booster
Hey everyone, I have read a couple of threads on using Cetane booster but I am not finding out anything about the quantity to use. I just bought my first diesel just before Christmas 2015. I took it in to the Ford dealer to do a LOF/fuel filter change not knowing how long since it been done last. They talked to me about buying the Motorcraft Cetane booster which I ended up buying two bottles to have on hand. I was watching a video on this stuff and it says to add 4 oz's on every fill up. So here is my question, wouldn't that be short on the proper amount seeing as my 2014 6.7L has a 35 gallon tank? It seems to me that I would be diluting the booster with fuel by not putting enough in to match the amount of fuel in the tank. I was thinking that I should put in 35 gallons worth on my next fill up because there isn't any in there currently and then figure out how much I need to add next time I fill up again. Does that makes sense?
Thanks,
Dave
Thanks,
Dave
I fall "almost" in the last category. I buy it by the case and try to use it all the time, regular in the warm months, the gel version when it gets really cold.
If I had to guess, I would say I use the 4/25 ratio 8-9 times out of 10 fill ups.
When I have slacked off a bit I will bump the additive ratio at the next fill up (which was 1.599 a gallon yesterday)
Point is, you do not have to be perfect with the ratio, although it wouldn't hurt.
It is 4 ounces to 25 gallons. Not really a big deal. Many never use it, many sometimes use it and many use it all the time.
Ok, but how does it stack up on a newer study, at least new enough where the 6.7 is concerned?
I just looked it up, 1 gallon to 2560 gallons, that equals 1 ounce to 20 gallons.
Amazon
1 gallon = $55 plus shipping ($16)
PM22
Amazon
1 gallon = $55 plus free shipping
I may not be a math wizard, but at least through Amazon PM-22 is a clear winner in cost per gallon, and it gets the FoMoCO's recommendation.
Amazon
PM22
Amazon
There are no newer studies, but the 6.7 is just another diesel engine as far as fuel goes. We would all love a new study but the place that did the last one couldn't pull another one together because of a combination of money, time and politics.
Thanks for all the replies. Being new to diesel trucks I am a bit leary of jumping in trying things without checking it out first.
I watched a video from POWERSTROKEHELP.COM - The Information Source for Ford Power Stroke Diesel Owners & Mechanics last night about using Archoil. Has anyone tried Archoil for an oil additive as well as a fuel additive?
Dave
Dave
The only thing to need to remember about oil is CJ plus rating and oem filters. No additives needed. Anti-gel fuel additive in colder climates and I use nothing otherwise. I threw a lot of money in the tank of my 6.0 for basically nothing. Just remember on time maintenance and oem filters. Also, if it ain't broke don't fix it.
2006-2007 is when USLD fuel became mandated and mainstream.
So any study done in 2007 needs to be qualified that it was done with the fuels at the time.
Since no link for this study was provided it is kind of hard to qualify the blanket statement that a study on additives that was published 2007 is accurate for today.
But if you decide to use an additive, and it is debatable if even needed, why use something that cost more and has no track record other then a test done 10 years ago?
The fuel requirement for each of the big 3 using the same pump has changed.
When I had my 2006 GMC I would occasionally add a quart of ATF or two stroke oil to the tank. I wouldn't think of doing that on any of the new diesels.
Your mileage may vary, but for me, if I decide to add anything to the fuel, it will be approved by the manufacturers.
